First post, by atom1kk
Hi, i have an issue that 3d mark is stuck on the refresh rate of the monitor.
I have a radeon 6850 inside and even with deactivated V sync in the catalyst options the system is capping it at the refresh rate. what might be the issue?
Reply 1 of 5, by Simmerhead
This is an old thread, but I've observed the same issue. The 3DMark score gets a lot higher when I adjust the monitor Hz from 60 to 75 (which is the range of my retro LCD monitor). In theory I suspect I could get an even higher 3DMark score with a monitor with higher refresh rates.
Simmerhead
¤ VGA-era DOS Gamer
¤ Vintage PC Hardware Collector
Reply 2 of 5, by 65C02
I've noticed this too, but only when I run 3D Mark 2000 on Windows 7 or 10.
XP and earlier, the frame rate is uncapped.
Reply 3 of 5, by Simmerhead
65C02 wrote on 2023-10-21, 17:27:
I just ran 3DMArk 99 and 2000 v1.1 and 2001 SE on Windows 98 SE, and the versions I have are definitely capped. Benchmarked a GeForce4 Ti 4200, FX5200 FX5500 and FX 5700 LE using nVIDIA Drivers 56.64.
Monitor refresh rate @ 60 Hz showed 60 fps in the racing demo on 3DMark 99. When adjusting the monitor refresh rate to 75 Hz, fps increased to 75.
Overall score increased 10-23% when running the monitor @ 75Hz.
Simmerhead
¤ VGA-era DOS Gamer
Reply 4 of 5, by umisery
I'm having this issue with with 3DMark99 but not 2000, any solutions?
Reply 5 of 5, by bloodem
umisery wrote on 2026-08-14, 03:15:
It’s a known issue, you need to force VSYNC off for Direct3D applications (either from the video driver settings, or with a 3rd party app such as Riva Tuner).
Are you running it on a modern or retro OS?
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
