First post, by enira
Hi,
I am currently trying to get sound to work in Windows 3.11
I already got it working under MS-DOS 6.11:
 Sound Blaster PCI 128 Initialization Driver, Ver 5.23
 Copyright(c) 1998-1999, Creative Labs., All Rights Reserved
fname: C:\DOS\SB\SBPCI.INI
 SB PCI @ Port 6100, IRQ 10
 Output Mode is Analog
 Initialization Complete
These are being loaded with SBLOAD and SBINIT.COM the and SBTEST.EXE seems to be working and producing sound.
However, in Windows 3.11 no sound.
What I already tried:
- Standard WFWG sound blaster drivers: they are for the non PCI cards correct? I got a card not found on these ones. (SET BLASTER=A220 I5 D1 H7 P330 T6 seems to be added to AUTOEXEC.BAT by the DOS drivers, but when using Port 220 and Interrupt 5 in Windows driver it says: The port setting does not match the card)
- apiwiz31 & 7501748, driver packages: doesn't seems to be doing much except kill the autoexec.bat config which I got working under DOS. I can't see a driver being added to Windows 3.11.
Anyone any idea how to get this card working under Windows 3.11?
