First post, by dreamscape86
I want to put an LCD on my Pentium 4 / Geforce FX 5500 / Windows 98 build
What is the best options for this? As most LCD's i've seen are pretty poor and have a fair bit of input lag. Are there any good ones which are well regarded by the retro community? Ones with high refresh rates at 1024x768 and preferably 1024x768 being it's native resolution so it looks sharp.
Shuttle XPC | Pentium 4 2.8Ghz | 512MB DDR 400Mhz | Nvidia Geforce FX 5600 Ultra | 32GB Sandisk Extreme Pro CF Card | Silverstone FX350-G 350W 80 Plus Gold PSU | Windows 98 SE
Reply 1 of 3, by Ensign Nemo
Would you be fine with a widescreen monitor with a 4:3 mode? The early 4:3 LCDs typically had poor refresh rates, but you would have more options with newer widescreen monitors.
This thread may be of interest:
Widescreen monitors and 4:3 aspect ratio compatibility thread
Reply 2 of 3, by kolderman
Dell 19" monitors work pretty well for all my retro needs. 5:4 but there are basically no 4:3 LCDs out there, and the stretch is not really noticable. Many late Win98 games support 1280x1024 anyway.
Reply 3 of 3, by Joseph_Joestar
kolderman wrote on 2022-10-09, 07:27:
And for the games that don't support 1280x1024, but can use 1280x960, you can choose aspect ratio scaling (or centered output) in Nvidia drivers. This gives you two thin black lines at the top and bottom of the screen but provides a very sharp image:
file.php?id=138430&mode=view
I think this only works with a DVI connection, at least when using 45.23 drivers under Win98. As I recall, ATi cards have a similar option as well.
