First post, by envagyok
I have a Soundblaster 8 bit clone card.
Need to find a speaker input.
Has someone any idea which header is the speaker in?
Thanks any help.
Thanks any help.
Looks like you have one of these (or a close variant) Anchor Electronics - Media Concept 2.0 Souncard - SB 2.0 clone with real OPL2
If you are a looking for an input to connect your motherboard's PC speaker out, I'm afraid there isn't one .
Thank You
The original CT1350 Have it?
Or how can i plug it to line in?
Sadly many dos game run without possibility ro change audio device from speaker to sb
CT1600 has one. I checked my CT1350B and it doesn't have it.
Visit my AmiBay items for sale (updated: 2025-08-01). I also take requests 😉
Thank you
The top port on that card is the Line In port, but I don't recommend using it. I recently reversed the Sound Blaster 2.0 CT1350B card that your card there is based on and my understanding is that it that treats the Line-In as mono audio, so it would probably make stereo audio into mono.
And yeah, this card doesn't support managing the PC speaker in any way. That's a pretty nice feature on the SB16
Thermalwrong wrote on 2022-10-07, 15:38:The top port on that card is the Line In port, but I don't recommend using it. I recently reversed the Sound Blaster 2.0 CT1350B card that your card there is based on and my understanding is that it that treats the Line-In as mono audio, so it would probably make stereo audio into mono.
Also, pre-SBPro cards don't have a controllable mixer, so anything fed to line-in likely won't be heard, unless the card is hard-wired to "mix" line-in with DAC output, which I don't know.
EDIT: The original Sound Blasters (pre Pro) do not output line-in through the speaker out . Sound Blaster 2.0 (CT1350B) line in not working.
From what I recall, it's really just routed into the mic input but with less amplification
