First post, by CMR779
I'm trying to run the game Heavy Barrel on my pentium 75 machine, but I'm having trouble getting the joystick to work. The game works fine in Dosbox, but on my p75 it won't read the down or right joystick controls. It only reads up and left. I've also tested the stick with joysticktests and pressing right or down on the stick runs the cross hairs completely off the target box. Could this be an issue with my joystick port or hadware on my sound card? I'm using an ESS card that's SB Pro compatible. I've also heard that running old games on Pentiums like this will cause issues because the cpu is too fast. Does anyone have any ideas? I'll try testing other games tomorrow.
Reply 1 of 8, by Gustavo
With many old games (i.e. Montezuma´s revenge), the joystick will only work correctly with a 4.77 MHz machine. Even a Turbo XT (10 MHz) can break joystick support on these games.
Why didn´t IBM go with digital joystick, like Atari, Amiga, MSX and almost all 80´s vidogame consoles.
Reply 2 of 8, by dr_st
Gustavo wrote on 2022-10-07, 10:31:
Analog precision? Is it utilized at all in games of that generation?
Reply 3 of 8, by Jo22
Flight simulators? Simulation games were much more playable with analogue joysticks.
And corporate dudes totally loved simulations.
Flight sims, golf sims, ..
Paddles from the Pong and Atari 2600 era were also analogue, afaik.
The C64 has a paddle-input via SID chip, too.
It's used as an X, Y input for the analogue mouse, too.
Edit: The Apple II had an analog joystick, too.
That's how an IBM / Apple II era joystick looked like (stereotypically).
Edit: This blog entry is interesting, too.
http://nerdlypleasures.blogspot.com/2012/02/p … sticks.html?m=1
    13.16 KiB
    Apple II joystick, SRC: https://www.the-liberator.net/site-files/retro-games/hardware/Apple-iie-iic-joystick/apple-iie-iic-a2m2012-joystick.htm
    184.07 KiB
    Tandy 1000 etc
    115.71 KiB
    IBM PC Jr
    36.28 KiB
    A CH products joystick (Mach series), SRC: Wikipedia
Reply 4 of 8, by Gustavo
Jo22 wrote on 2022-10-07, 18:05:
Yes, I know, but it really ruined the gaming experience for every other genre.
The king of (bad) joystick is the TRS Coco with its non auto-centering joystick and in many games the joystick control is the only method available.
I had one joystick very similar to these in the pictures. Flying with a flight simulator was really fantastic!
Reply 5 of 8, by BitWrangler
Amiga also supports analog sticks by the way. Need an adaptor for PC plugged ones obviously, but I believe there are some Coleco or Atari ones you can plug right in.
Reply 6 of 8, by Jo22
Gustavo wrote on 2022-10-08, 00:21:
Yes, I know, but it really ruined the gaming experience for every other genre. [..]
Understandable. But in ~1981-1985, the IBM PC totally was a manager's toy.
It was foremost used by business people.
Stiff people in suits, with neckties and shiny shoes.
They only played "serious" games. Or so it seemed.
Flight simulator, golf, power plant simulator, slot machine, strip poker..
There was no time for playing Galaga, Asteroids or Pac-Man.
Personally, I kind of have a soft spot for the analogue gameport - but not for its, um, playful side.
I too had issues with calibration in games, albeit not so often as the others.
What I like is that the IBM Gameport was a cheap Analog/Digital Converter (ADC).
Not much unlike the microphone input of a soundcard.
It could read natural information of our real world,
like a reading from a temperatur sensitive resistor (NTC/PTC) or a light sensitive resistor (LDR). Yay!
In other words, the IBM PC could be used as a slow oscilloscope or oscillograph.
Nearly out of box!
And the best of it - BASIC had the commands built-in (STICK&STRIG)! Double yay! 😁
Cool! Me, too! I had the CH Mach 3, I believe.
I used to play this game with it:
https://www.mobygames.com/game/dos/mig-29-fulcrum_
I know, it's perhaps not best/right time to admit this, due to the geopolitical situation. 😅
Reply 7 of 8, by Gustavo
Jo22 wrote on 2022-10-08, 05:02:
Hey!! I did that in the late 80´s, with QuickBasic, and plotted a graph or made some weird sound with the readings!! Great time!👍👍
Reply 8 of 8, by CMR779
Thanks for the replies. I tested my joystick with a multimeter, and the high numbers were pretty high. The right and down movements capped at about 180K or better. It was one of those cheap quickshot sticks. Maybe I'll just put together a homebrew stick out of some arcade controls. Atari 5200 fans have been doing them, and I think the circuits would be pretty similar for a pc.
