First post, by RETROKOMODO
Hi folks,
I'm just about to embark on a project that's going to take a while to complete - running benchmarks on the following cards:
AGP 9600xt from 2003,
AGP 9800 pro from 2003,
AGP 7300 GT from 2006,
AGP 7800 GS+ from 2006,
PCI-E 7950 GT from 2006,
AGP x1950 pro from 2006,
PCI-E HD 3850 from 2007,
AGP HD 3850 from 2008,
AGP HD 4650 from 2008,
PCI-E HD 4850 from 2008,
PCI-E HD 6870 from 2010
Some of them may not work, as not yet tested and just arrived from Ebay. These are the only cards I have to hand, so can't add more even if I wanted to! all will be running the last available drivers for each card having first DDU's the previous card's drivers off. Some of these cards support higher than DirectX9, but as some don’t, I am not using benchmarks that run on a DirectX version higher than 9 so i'm using Win XP SP3 as I normally do, and the system i'm using is:
ASROCK 4CoreDual-VSTA
E7600 Core 2 Duo @ stock 3.06ghz
About 3.35GB of 4GB DDR2 Hyper-X in dual channel
8xAGP & 4xPCI-E slots. Considering the speed of the cards i'm hoping there won't de too much of a throttle on the PCIE slot - but I guess i'll find out!
I'm using 3dmark 2001se, 3dmark03, 3dmark05, 3dmark06, aquamark3, and the Unengine sanctuary v2.3, tropics v1.3 and heaven v3 (v4 won't install) benchmarks. Game benchmarks will be far cry 2 set to optimal at 1080p and 720p, lost planet 2, stalker: call of pripyat (medium settings), world in conflict (medium settings), crysis (medium settings), Half Life 2: Lost Coast (maximum settings) and FEAR (medium settings).
Any suggestions on alterations to the lineup? The combination of cards and benchmarks is already going to take ages to get through as and when I can find the time, but suggestions welcome!
