First post, by Christiano
Hi guys,
I need help to run Desert Strike game in MS DOS on a Celeron 400 Mhz computer.
Desert.exe will not start due to "divide overflow" error. I read that is happening because my CPU is faster than 233 Mhz.
I found a patch on google at Megagames.com but the download link is not functioning https://megagames.com/patches/desert-strike-r … -overflow-patch
Do you happen to have this patch ? Or if not, do you have an already patched executable than you can share with me so that I can play the game too ?
Just for bragging, I'll post my retro configuration too:
Luckytech P6LX7 (based on 440LX chipset) / Celeron 400 Mhz / Matrox G450 AGP / CMI 8330 ISA soundcard
v
v
!! UPDATE: >>> the solution that worked for this game was to disable CPU cache in BIOS. It reduced anything to a crawl, but the game ran adequate.
