First post, by matze79
New Project:
The attachment 287clock.png is no longer available
80287 Clock Board.
it allows to clock 287 FPU at different Clockrate.
For Example to run 6Mhz 286 with 20Mhz FPU.
Not yet tested 😀
i will order it after moving on 5.11
Reply 1 of 3, by Jo22
Cool! 😎👍
Um, if I'm allowed to make an advice..
Maybe the crystal oscillator can be buffered, for an even cleaner TTL signal.
Because, I had issues myself with a modded Mega Drive..
My 68010 isn't exactly stable with the separate clock. Another user fixed this issue with an HD74LS14, I think.
That's why it came to mind.
Reply 2 of 3, by matze79
Its buffered trough the 4bit Counter, i think this should suffice.
But it seems like i can omit the counter.. and instead use a oscillator directly.
Then maybe a single buffer gate would be enough.
Madao checked his Adapter.
And it does not care about the 287 datasheet and 33% Duty Cycle and its working.
Data:
The attachment 287-1.png is no longer available
The attachment 287-2.png is no longer available
The attachment 287-3.png is no longer available
Reply 3 of 3, by matze79
Proud Test Canidates arrived!
The attachment test_canidates.png is no longer available
More Pictures from Madao:
The attachment socket_1.png is no longer available
The attachment socket_2.png is no longer available
so 50:50 Duty Cycle will suit all 287 well.
