First post, by Cosmic
Hi everyone, I'm working on an early 2000s XP machine without on-board sound. It's a 440BX system with a 1.4GHz Celeron and 1 AGP, 3 PCI, and 3 ISA slots. Fast connectivity was more important to me than PCI sound and EAX/A3D, so I've used the PCI slots for an ATA133 card, a USB 2.0 card, and an Intel Pro ethernet card.
I'm left with choosing an ISA sound card. DOS compatibility isn't super important as I have a K6 machine for DOS. Are there any particular ISA sound cards that would be a good match for this system?
These are the ISA sound cards I have on hand:
  • SoundBlaster CT2290 - true OPL3 card, it's in my K6 system for now
  • SoundBlaster CT4170 Vibra 16XV - fairly integrated card, CQM
  • Aztech 138-MMSN855 - interesting card with a modem, but not sure how good it is
I would really like an AWE64 gold, I understand that's one of the last and greatest ISA cards, but they're pretty expensive (~$200 USD). Maybe a regular AWE64 (green PCB and much cheaper) would be a good match?
Other relevant threads I read:
Using SBpro and SB16 ISA on WinXP and Win7, possible?
List of ISA sound cards working under Windows XP and Windows 2000
Rigs: Harris 286-16 [WIP] | Am386 DX-40 | i486 DX4-100 | MMX 233 | K6-III+ 600 | P!!!-S 1.3GHz | XP 3200+ 2.3GHz | Q6600 3.2GHz
Reply 1 of 9, by Gustavo
Cosmic wrote on 2022-10-16, 19:35:
These are the ISA sound cards I have on hand: […]
Hi!
CQM sounds very bad with FM music. I once got a SB AWE32 with this chip and couldn´t stand it.
Can´t recommend.
Reply 2 of 9, by The Serpent Rider
Sound card with 48kHz output is preferable. ISA sound blaster never had it and Aztech most likely neither.
Reply 3 of 9, by Jo22
Windows Slund System (WSS) was 48 KHz.
Reply 4 of 9, by Cosmic
The Serpent Rider wrote on 2022-10-16, 20:50:
Jo22 wrote on 2022-10-16, 21:04:
Thanks! I wasn't thinking about the sample rate so that helps narrow the choices down a lot.
I found a post from 2014 on another forum that lists a bunch of ISA sound cards and sometimes includes sample rate.
http://www.oldschooldaw.com/forums/index.php?topic=674.0
I filtered by 48kHz and posted the results here for anybody else looking for these cards. Looks like there's plenty to choose from and some are fairly inexpensive.
ESS ISA CHIPSETS  (Audiodrive Series):
ES1869 Controller+Codec 16-bit 48KHz, Integr. OPL3 clone, MPU-401, PnP, dual joystick, Full-duplex, IDE, Spatializer 3-D VBX.
CRYSTAL ISA RELATED CHIPSETS (only the most common):
CS4231(A) Codec 16-bit 48KHz, WSS Compatible, ADPCM, Full Duplex.
CS4248 Codec 16-bit 48KHz, WSS Compatible, ADPCM, Full Duplex (as CS4231 without pulse code modulation
CS4232 Controller+Codec 16-Bit 48KHz, PnP, SB/SBPro/WSS/MPU-401 compatible, IDE.
CS4236 Controller+Codec 16-Bit 48KHz, PnP, SB/SBPro/WSS/MPU-401 compatible, IDE, Integr. OPL3 clone.
CS4236B Controller+Codec 16-Bit 48KHz, PnP, SB/SBPro/WSS/MPU-401 compatible, IDE, Integr. OPL3 clone, WT digital interface.
CS4237B Controller+Codec 16-Bit 48KHz, PnP, SB/SBPro/WSS/MPU-401 compatible, IDE, Integr. OPL3 clone, WT digital interface.
CS4235 Controller+Codec 16-Bit 48KHz, PnP, SB/SBPro/WSS/MPU-401 compatible, IDE, Integr. OPL3 clone, low cost.
ADLIB ISA SOUNDCARDS
MSC Wave Pro 16 AD1848K SoundPort, Breve misc chips, 1MB wave table GM/GS MT32.
ENSONIQ ISA SOUNDCARDS
Soundscape S-2000 AD1848KP, Motorola 68EC000, OTTO GM/GS Wavetable 2MB ROM, M-CD
Soundscape Elite AD1848KP, Motorola 68EC000, OTTO GM/GS Wavetable 2MB ROM, M-CD, IDE, ESP daughtercard
Soundscape II: AD1848KP, Motorola 68EC000, OTTO GM/GS Wavetable 2MB ROM, M-CD, IDE, ESP connectors
Reply 5 of 9, by Grzyb
16-bit Aztech cards are compatible with WSS.
So, that Aztech card most likely does support 48 kHz.
In 2003, I voted in favour of joining the European Union. However, due to recent developments - especially the restrictions on cash usage - I'm hereby withdrawing my support. DOWN WITH THE EU!
Reply 6 of 9, by BitWrangler
Yah, back in the day I liked using MSS/WSS in anything that supported it on my Aztechs, the SB modes seemed to offer bug for bug compatibility with reversed stereo and note hanging in a lot of games.
Reply 7 of 9, by mwdmeyer
I remember I had an ESS ISA sound card on my Duron 800, I later upgraded to a Sound Blaster Live Value PCI. I got a big speed up in many games due to ISA Soundcard bottlenecking the machine.
I would suggest finding a mobo with more PCI slots 😀
Reply 8 of 9, by Cosmic
Grzyb wrote on 2022-10-17, 00:37:
The Aztech ended up only supporting 44.1 KHz :[ oh well. I bought an inexpensive Crystal based ISA card with no frills and simple layout. I'll update with results when it arrives.
mwdmeyer wrote on 2022-10-17, 03:27:
I wish! I have an interest in mini/baby AT boards lately (I have 4 so far). It's been tough finding 440BX + AGP + more than 3 PCI slots in this form factor. They exist, but I'm happy with the compromise so far.
A couple photos of the Aztech. I think it's kind of ugly. :p
Under Windows:
Reply 9 of 9, by BitWrangler
Yah, I have this one I think (Model numbers tend to scramble in my head) https://theretroweb.com/motherboards/s/pcpart … bxb847d-35-8847 with just the 3 PCI, haven't found a way to get a PIII going on it yet. It's very anchored in PII era for a BX... guess I could screw around with BIOS from other boards or something. Not playing in this era at the moment though.
