First post, by GabrielKnight123
I have a working Asus Rampage 4 Black Edition X79 socket 2011 with a proper kit of 64GB 1866MHz DDR3 ram and an Intel i7 4930K CPU @ 3.4GHz ~ turbo of 3.9GHz 6 cores 12 threads I'm considering selling it but many of these motherboards have a problem of sorts where the PC will go into a sleep state and cant be woken without a power down and turning back on there seems to be no fix as other people with this board think its a driver/software problem to do with windows 10 and Asus but because of this If I was to sell it, motherboard + CPU + Ram and probably closed water cooling loop what do you guys think it would be worth. It has no other problem than the sleeping "bug" and it happens randomly so maybe one day it will happen once and another day it will happen a few times and another day it wont. I've tried all sorts of things to fix it and tests and hardware changes but nothing can fix it so its time to move it on.
