First post, by irkinex
Hi everyone!
I would like to introduce myself as I am a new user of this fantastic forum that I have recently discovered 😀
I'm starting to learning a about the retro pc hardware and try to upgrade the second pc that my father bought 24 years ago a INTEL PENTIUM II 350MHZ MMX, with a few things that but with some things that I wanted at that time, 128mb of ram instead of 64mb, voodoo 3 instead of S3 virge 3d trio and sound blaster live ct 4830 instead of Ensoniq ES1371 what they originally had, I also thought about changing the original 6gb hard drive for a 20gb one and here comes my doubt.
I would like to keep the original hard drive with the windows 95 OSR 2.5 operating system and use the 20gb hd to store the games.
How could i do it? I need to put the 20gb as slave primary or as primary master?
Excuse my ignorance but it's the first time and I'm still learning day by day.
Thank you very much!
Reply 1 of 9, by zyga64
If you want to connect it using the same ribbon as the old one - you have set it to slave.
One IDE channel allows to connect two devices. One must be set as master, second as slave. As simple as that !
Some of the IDE drives needs different jumper settings for master, and different for 'single drive' (only one drive connected to IDE channel).
But it should be described on the drive itself.
There is also third possibility. Set both drives to "cable select" and connect those to one IDE channel. They should configure itself for master/slave.
But it is least compatible option.
8088@8 /640k /TVGA9000C /ALS100+TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 2 of 9, by irkinex
Thanks zyga64!
I have another question, to format the 20gb hd I need to do something special? I mean format with the cd on windosw 98 for example create a dos primary partition and then I need to do something else?
This hd comes from antoher pc with windows xp
Thanks again!
Reply 3 of 9, by zyga64
Windows 98 will recognize new drive (even if it is not detected by BIOS, you can overcome BIOS limitation 😀 but not file system on it.
Hard drive needs to be partitioned for Windows 98 first, because Windows XP uses NTFS file system which can not be used by Windows 98 by default.
You can do it after connecting it to Windows 98 computer (it's the fastest way).
1.) Run commandline (press Windows key + R, and type command.com).
2.) type 'fdisk' and press enter.
3.) Confirm you want to use 'large disks' - it allows you to create Fat32 partitions, if you decide not to use 'large disk', you will be able to create partitions with size up to 8GB (fat16 limitation).
4.) change active hard disk to the new one, display its structure, ensure it's the correct hard drive
5.) delete all partition from it (first all 'logical' inside 'extended' partition, than extended partition itself, next 'primary' partition) <- pay attention not to use old disk, you can lose all data !!!!
6.) Create 'primary' partition with max size
7.) Exit fdisk, close command.com window, reboot computer
😎. After reboot, Open "My computer", right-click on new created partition and choose 'Format', check 'use quick formatting'.
That's all !
You can do it in MS-DOS mode prior to loading windows GUI, but it will be way slower.
[Edit] Just the grammar, not the content.
Reply 4 of 9, by Jo22
[..]because Windows XP uses NTFS file system which can not be used by Windows 98 by default.
Yes, by now it does use NTFS. In early 2000, Windows XP was often installed on FAT32, though.
Windows XP supported both FAT32/NTFS for installation..
Otherwise, upgrading from Windows 9x to XP wouldn't have been possible in first place. 😉
Reply 5 of 9, by irkinex
thanks a lot zyga64!
Reply 6 of 9, by leileilol
Win95 OSR 2.5 should be able to do FAT32 20gb with that second drive, the win98 part isn't neccessary. It's already right on the edge of stock Win95's CPU support though. 😉
Reply 7 of 9, by BitWrangler
zyga64 wrote on 2022-10-20, 08:27:
IDE cables intended for Cable Select mode operation have a line cut, you can tell this as a pinhole when you hold it up to the light.
Reply 8 of 9, by zyga64
leileilol wrote on 2022-10-20, 16:46:
You are of course right. Looks like I didn't read first post carefully. For me Pentium II means Windows 98. Windows 95 is just too... plain visually (for me).
But besides that, my point was to do partitioning after starting windows GUI, in plain Ms-dos mode it would take ages...
Reply 9 of 9, by irkinex
Everything it works thanks ziga64! Yeah I know windows 98 is a better option for this machine, but I grow up with win95 in this machine and another 486 its pure nostalgia, but i want build windows 98 too in the future 😀
