First post, by smtkr
I bought an old TFT LCD from eBay and after turning it on, there are these splotchy dim spots (see attached). The screen is clean
What causes these? Is there a way to fix them?
1.73 MiB
Reply 1 of 2, by adalbert
I had something like this in an LCD that got moisture in it, it also might been due to mechanical damage (pressing on these spots too hard, so the diffusion layers got mangled). It's an issue with the internal diffusion layers of the LCD screen and unfortunately I don't think there is an easy fix for that, even if you disassemble the panel and manually clean the diffusers, it probably would be impossible to realign them correctly, and also a lot of dust could get inside in the process. I don't think this is a problem with the "liquid-crystal" part of the LCD.
Reply 2 of 2, by rasz_pl
lighter ones can be moisture and cleaning them is possible https://www.eevblog.com/forum/repair/computer … monitor-blotch/
darker ones is damage, either mechanical or heat/age related and permanent
