First post, by DimSumthing
Hey there, folks! Long-time unregistered lurker, first-time registered poster.
First, I'd like to apologize in advanced if my forum etiquette is a bit rusty (it's been a few years)! If this isn't the correct place to post this, I'd appreciate a heads-up. 😀
I've recently acquired a Biostar M5ALA v2 motherboard, but I noticed that two capacitors seem to have been pulled out (see circled areas in pictures below). Would anyone know where I might be able to find information about the values of these missing caps?
Thank you!
Reply 1 of 3, by pentiumspeed
Cache IC is rated at 66MHz, denoted by "10ns" on the cache IC. You need 5ns cache to reach rated 100MHz.
Cheers,
Great Northern aka Canada.
Reply 2 of 3, by rasz_pl
CT2 looks to be the same as CT1. CT25 looks like same cap as the one ear Tag ram above mosys chip.
Reply 3 of 3, by majestyk
pentiumspeed wrote on 2022-10-24, 19:44:
Cheers,
MoSys, like Samsung and others, has their own naming scheme: "-10" does not mean 10nS, but 100 MHz.
So everything´s alright here!
https://www.digchip.com/datasheets/parts/data … 364K64L-pdf.php
