First post, by nathanieltolbert
I am still working on the ASUS K7M but I made the mistake of bidding on a lot of motherboards with 2 socket 7 and 2 socket 3 motherboards. They arrived, and 1 of each socket type works great and the other doesn't. On the Socket 3 board I get a post code beep that is strange. I'm sure it has a meaning, but I don't know what it is. I have ordered one of the Post Code cards so I can see the specific hex code for where it's failing, but it won't be here for a bit.
The board in question is a Young Micro Systems CROSS 486G-VLB. The Varta battery was removed before I got it. There was a bit of corrosion on the top of the board, but none visible on the bottom of the board. That's not to say that the board is damage free though. It's pretty clear that this board was treated roughly at least once before coming to me. On the back in an area that looks like a ground plane there is a massive gouge, but it doesn't appear to reach any of the pins nor does it go completely from one side of the plane to the other, so there doesn't appear to be a break in the plane. There is also what appears to be damaged plastic on the VLB slots and at least one of the ISA slots. Once I get my battery replaced in my multimeter again I will test for continuity. The other thing I immediately noticed was the metal arms that hold the 72 pin simms in place were very clearly bent out of shape on Bank 0 and Bank 1. I bent them back, but there is a part on Bank 0 I wasn't able to bend back as it was curled in on itself and I worry that I may break it off if I force it. And the last thing I noticed after all of that is that it appears that one corner of the socket is lower than the other three corners? The keyed corner, when the CPU is flat in the socket appears to be maybe 1 or 2 mm lower, which results in the pins being exposed in that corner. I have never seen this before, and maybe that's the problem?
After checking the board over visually I inserted two 8MB simms in Bank 0 and Bank 1. Plugged in the AT power, and an ISA Video card. pressed the button. I got a strange post code beep. For 4 seconds there is nothing. Then the speaker emits a 1 second low tone beep, there is a pause of 3 seconds, then another 1 second low tone beep, followed by another 3 second pause and then 1 second low tone beep. After that there is a 10 second pause and the pattern repeats itself. I checked all of the jumpers as this board has a ton of factory set do not change. Several of them were changed. I set the back to factory default. No change. I have taken some pictures of the board, and I will post them. When I flipped the board over, I noticed more damage. I fear there are half a dozen small traces that were gouged from this board at the very least being stored on top of another board. I apologize for coming here so constantly. I hope to have the post code card by Saturday and hopefully that will help me. Thank you for any questions or suggestions on what to test to see if I can get this board running. I will pick up a battery for my multimeter after I get my daughter from school so I can test continuity.
-Edit- I got the system analyzer card. When plugged in, the machine hangs on D3. I couldn't find anything initially regarding this, until I found a manual inside of the box. It indicated that for AMIBIOS that D3 indicates Memory Sizing. So I am going to guess, that this means that it cannot find the RAM. I cannot at this point ID if this is because of damaged traces on the bottom of the board, or if it's because RAM I think is FPM is actually EDO, and won't work with this board. If anyone knows anything more about this board, I would really appreciate the help. If I can get it to fully post then I can make a dump of the BIOS for The Retro Web and any additional items that the site might need regarding the board.
Reply 1 of 19, by nathanieltolbert
Here are the pictures of the back of the board. I can't believe I missed the other scrapes, they are very visible. I was so focused on the one big gouge. Another thing I noticed is that a lot of the pins are bent over on the back. I noticed a few with touching the solder pads of other pins, so I carefully bent them back up with some tweezers. I'm sure I missed a bunch, so I will look more closely here later.
Reply 2 of 19, by Horun
nathanieltolbert wrote on 2022-10-27, 20:02:
Visible here is the scratched and damaged plastic on the VLB slots.
Here is a picture of the ISA slots that are slightly damaged. Unknown if that would cause issue.
Most likely caused by other boards or hardware laid on top and then rough handled. Have seen boards stacked on top of each other in a stack (no boxes, bags or padding) and was obvious some one pulled one out from above and the solder/pins from ISA slots scratched the board below. Just a guess in your case but likely. (or they kicked it across a driveway ;p )
Reply 3 of 19, by nathanieltolbert
Horun wrote on 2022-10-28, 01:19:
I don't know where the damaged happened. I can say that the 4 boards were packed in individual boxes in anti-static bags, wrapped in bubble wrap, and then they taped the 4 boxes together to make it one box to ship. I had never seen anyone do that before. It was pretty neat to see, honestly.
Reply 4 of 19, by rasz_pl
looks like someone is running a side business picking recycling facility trash end reselling as "not tested" 😀
Necrowares recent video shows how to deal with scratched traces https://youtu.be/trwg5QzkApk?t=445
Reply 5 of 19, by nathanieltolbert
You're probably right. I want to repair them so I can build machines with them and then give them away on my stream. I guess I'm not much better in the overall scheme of things.
Reply 6 of 19, by nathanieltolbert
I got my analyzer card. Plugged it in and booted up. Now I'm stuck again because the code it freezes on I can't find anywhere in the BIOS codes for Amibios. It throws a d3 code. I cannot seem to find what it is that is the issue.
Reply 7 of 19, by nathanieltolbert
Okay there was a manual buried under the foam in the box the card came in d3 indicates memory sizing next. So it can't find the memory at all?
Reply 9 of 19, by nathanieltolbert
That is possible? There is those scratches on the the traces on the back of the board as shown above. I don't know if they are ram address lines. Heck, at this point I don't even know if all the ram I am trying is not EDO. I thought I had a 4MB fpm module but now I'm not sure.
Reply 10 of 19, by nathanieltolbert
I got by multimeter out and tested all of the traces. So the big gouge does not seem to have affected anything. However, all of the traces you can see gouged in the picture have no continuity as far as I can tell. I don't have a tone continuity tester so I have to look at the screen, and so I get a flash of numbers, but then it goes back to 1. When there is continuity a series of numbers count down to 0.000, but it doesn't do that on any of the traces. I followed the traces to solder points and via holes and I got nothing. Several of the traces connect directly to the Memory slots. But not the first slot. The first slot traces have no damage, but I still see nothing with the ram. I guess I need to figure out how to repair traces? I don't have the magnification or the wire or the steady hand I think to solder very tiny wires. I'm positive this board will work with repairs. I just can't do it myself I think.
Reply 11 of 19, by rasz_pl
Wait. I totally assumed your poste last week with scratch pictures was meant to say "I found and fixed those" 😀 yes, they all need patching up.
Reply 12 of 19, by nathanieltolbert
rasz_pl wrote on 2022-11-03, 04:29:
I wish I could. I don't have a soldering tip small enough and I don't have any wires. I have watched I believe it's Necroware repair traces on Youtube, but I have no experience. I don't know. I would like to get it fixed and cased so I can give it away. I will have to see if I can find someone who can fix it if I can pay them. Sadly, the excellent repair man we had here passed away 6 years ago. He was a very good friend. No one else here does board level repair. I need to get some test boards with tiny traces to practice with before I tackle something like this.
Reply 13 of 19, by rasz_pl
-where is 'here'?
-you dont need tiny soldering tip, tiny tips are worthless and I dont know who, other than people who dont know what they are doing, they are aimed at. Even when micro soldering small SMD components I use big chisel/bevel tips and let flux and surface tension do all the work for me.
-the best wire (thin enamel coated) for this kind of repair is what is used in transformers, you can pull one from a piece of worthless salvage electronics. Either from power supply transformer or cell phone vibration motor windings.
Reply 14 of 19, by nathanieltolbert
rasz_pl wrote on 2022-11-03, 08:03:
-where is 'here'?
- 'here' is where I live, in the middle of the US. I don't really know many retro community people who live here. I should get out and meet people, but my introverted nature gets the best of me far too often than I should let it.
- I don't have a chisel tip. My soldering iron takes T-5 tips, I believe? So if you have any recommendations on which brand and type I would appreciate the information.
- What gauge should I go for? I have a friend who suggested I use an old IDE cable to make some temp bodges to see if that corrects the issue before I try to repair the traces like I have seen on line. Is that a good idea? I don't think my skills of soldering are very good and I worry that I will ruin the board while testing this. I don't have anywhere that I can harvest the wires from transformers or cell phones, so if there is a place I can buy the wire, I will do that.
I know I shouldn't be worried about making the issue worse considering the board doesn't work currently. I just hope to fix this so it can go back out into the retro community. I would hate to be the cause of another Computer motherboard being un-usable.
Reply 15 of 19, by rasz_pl
nathanieltolbert wrote on 2022-11-04, 00:01:
find a local cellphone repair place, they will be able to patch those traces for you
anything that isnt a sharp needle tip, soldering is about heat transfer and thin sharp tips suck at it making you bump up temperature to work at all
something like Frys Electronics Radio Shack, hmm Micro Center? they have small spools of wires, maybe they will have 30 gauge kynar/enamel wire
for junk hardware hit local goodwill, recycling centers and big store garbage bins
Reply 16 of 19, by nathanieltolbert
rasz_pl wrote on 2022-11-04, 09:21:
I called 4 different cell phone repair places. All but one of them said they wouldn't do it. The fourth place wanted to charge 600 bucks. So that's not feasible for me. Note that I didn't look at other local suburbs. Just specifically in the town that I live in, which is a bit small. I think they highballed me on price because they didn't want to say they wouldn't do it.
So the normal tip I use should work? It's just a T15-BLL. I also have a T15-ILS and a T15-D16 if one of those would work better.
I do have a Microcenter somewhat near by. I know their website is not 100% accurate, but the smallest gauge they have on the site for my local store is 24 gauge. Is that going to be small enough?
Reply 17 of 19, by rasz_pl
nathanieltolbert wrote on 2022-11-05, 19:50:
were those Apple service centers? 😀 I meant a local mall cellphone guy sitting somewhere in a corner replacing batteries, cracked screens and resoldering charging ports, that kind of cellphone repair.
oh T15, you said T5 earlier so I didnt even bother. T5 is 900 series ancient tip over heating cartridge.
T15-BLL and T15-ILS have this appearance of being great for small SMD to a person that never did small SMD, personally I find those types of tips useless. T15-D16 is ok all around.
might as well sacrifice old headphone cable
Reply 18 of 19, by nathanieltolbert
rasz_pl wrote on 2022-11-05, 20:35:
I wouldn't contact an Apple service center. I want to fix the board, not have it replaced with a soldered down mess of a board that doesn't allow for any sort of upgradability. 🤣 But there are a bunch of other cell phone repair stores in nearby towns. The common thing I get is, 'we don't work on computer boards.' There were a couple of small computer stores that might do repair in the area, but they have all closed down in the last couple years. Probably thanks to the pandemic. They probably would have been fantastic.
Yes, I was wrong. For whatever reason I thought they were T-5. And when I went to look at T-5 tips, I saw that they didn't look like what my soldering iron used. So then I looked up my soldering iron to get the right type. I may have one of those T15-D16 tips here. When I bought my little solder iron, which is a low end KSGER it came with a dozen different tips.
I don't have any old cables like that. Should I just buy some solid core 30 gauge off of Amazon?
Reply 19 of 19, by rasz_pl
This looks ok https://www.amazon.com/Treedix-Copper-Wrappin … l/dp/B08D6D1TKH
EDIT: but you still need to get a piece of ~20-30 year old electronics to practice on before doing the board. New proto boards/universal soldering kits are not the same as soldering old boards. I dont think I mentioned you could also look for local hacker/maker spaces and radio amateurs.
