Socket 4 VLB - enabling full 1MB cache
First post, by Batyra
Hi Everyone!
For a long time I'm on a quest to build quite exotic machine Socket 4 VLB. I know that VLB has more sense with 486, but as I mentioned it is going to be exotic build.
I have not found anywhere this exactly motherboards scheme. The closest one (from the same manufacturer and very similar) is here: https://stason.org/TULARC/pc/motherboards/N/N … LEGANCE-PE.html
I have proper cache sticks - all tested, not fake etc. Tried it in other motherboard - working fine as 1M.
The problem is cache.
Motherboard does not recognize full 1MB, only 256. And I'm thinking what can I do to enable full 1MB. I'm thinking of placing three missing chips but I have to identify them first. Maybe some bios test from other motherboard?
Anyone have any clue what can I do? Maybe similar problem?
If anyone have similar Socket 4 + VLB + PCI motherboard PLEASE!! contact me.
I just collect the hardware — others make it run.
Reply 1 of 21, by CoffeeOne
Hello,
I don't have such a mainboard, but did you set the jumpers to the 1MB setting (after inserting the chips)?
Reply 2 of 21, by Batyra
Thak you for reply. Yes, of course. I've tried all obvious actions. And even trying two different (also tested) sets of cache sticks.
Reply 3 of 21, by kixs
I always thought the TAG has to be more then 256KB for 1MB cache. Usually 64K x 8.
Reply 4 of 21, by CoffeeOne
Batyra wrote on 2022-10-30, 08:46:
That's weird.
So when you insert the 8 sticks of 128kx8 and close the 2 jumpers the Bios reports 256kb, right?
Is it really 256kB? Did you confirm it with a test program like speedsys?
When you have 256kB working with the 128kx8 sticks, it is very unlikely that the 128kx8 chips are bad. Could be a mainboard or Bios issue I believe.
Reply 5 of 21, by Roman555
Batyra wrote on 2022-10-30, 08:23:
Hi,
Have you known there's a schematic diagram for a PCI/VLB motherboard based on OPTi Python 82c547/82c546 chipset?
Will it help? Theoretically you will be able to understand whether electrical connections of cache banks are OK.
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 6 of 21, by majestyk
kixs wrote on 2022-10-30, 08:56:
This was my first guess also. But the DIL28 socket is limiting TAG size to 256K.
Some (rare) mainboards demanded a different TAG organisation like 16Kx16 (or whatever) instead of 32Kx8. These are sometimes hard to find.
Maybe there´s some info in the silkscreen printing inside the socket?
Reply 7 of 21, by Disruptor
I think that's it.
It seems like that board will support 512 kB L2 cache with eight 64K x 8 plus tag with 32K x 8.
In my Shuttle HOT-433 I use eight 128K x 8 plus tag with 64K x 8.
Reply 8 of 21, by CoffeeOne
Disruptor wrote on 2022-10-31, 20:46:
I think that's it. It seems like that board will support 512 kB L2 cache with eight 64K x 8 plus tag with 32K x 8. […]
I think that's it.
Nope.
Obviously for that Pentium chipset 32Kx8 tag size is enough for 1MB cache. He attached the manual.
Reply 9 of 21, by Disruptor
CoffeeOne wrote on 2022-11-01, 15:46:
Nope.
Oops. Sure. It isn't a 486 xD
Yes, you're right then.
It's because the data bus width is 64 bit and there's just one bank, not two like on a 32 bit 486.
Reply 10 of 21, by Batyra
Thank you everyone for replying. Unfortunately no solutions found so far. Maybe some of you have "proper" manual? O knowledge of three chips that are missing?
Reply 11 of 21, by CoffeeOne
Batyra wrote on 2022-11-02, 19:06:
Hello,
Please answer my questions above.
Reply 12 of 21, by Batyra
CoffeeOne wrote on 2022-10-30, 08:58:
That's weird. So when you insert the 8 sticks of 128kx8 and close the 2 jumpers the Bios reports 256kb, right? Is it really 256k […]
That's weird.
When you put 1MB and jumpers are set as for 256 it recognizes 256... when jumpers are set to 1M there is "No cache".
Also the motherboard recognizes CPU (Pentium overdrive 133) as 100... but test proove it works as 133 - so motherboard issue.
Reply 13 of 21, by CoffeeOne
Batyra wrote on 2022-11-02, 20:39:
That's weird.
Hi, OK:
for this case:
Is the 256kB cache working in this case? Confirmed by speedsys?
Reply 14 of 21, by Batyra
CoffeeOne wrote on 2022-11-02, 22:28:
Yes
Reply 15 of 21, by CoffeeOne
Batyra wrote on 2022-11-04, 11:20:
Yes
Hi, then I assume (to 99%) that your cache chips are good!
So I believe it can only be the jumper settings. I mean it could also be the case that the boards works fine with 256kb, and not correctly with 1MB, but that is unlikely for me.
Reply 16 of 21, by Batyra
Problem solved!
I've tried different BIOS... it was from exactly (99%) the same motherboard from the same manufacturer and chipset but with socket 5 not socket 4... Revision of bios was the same - I was sure it's identical but after change all started to run!
It recognize my 133 overdrive as pentium 100 but it runs like it should... I think I'll ask someone who knows how to deal with micro-codes or how it is called to change it to be named properly!
Meanwhile - thanks to everyone who tried to help!
Reply 18 of 21, by WJG6260
Nice work on getting the cache working!
I’ve been meaning to chime in on this thread, as I own the Socket 5 version of this board.
In fact, if you got the BIOS from TRW, I dumped it for their archive.
One note about the Elegance P90’s BIOS that might be of interest to you: on the Socket 5 version of this board (and presumably, on your board with the appropriate adapter), you can run a WinChip, WinChip2, and even a POD MMX without issue. This is not the case for most Pentium/VL BIOSes.
I have had issues getting 1MB cache working on mine, but I presume it’s all jumper quirkiness.
Do you mind sharing your jumper settings? I am curious to see if I can get the same results on this board’s Socket 5 brother.
Great job, and I hope you enjoy this board! Socket 4 and VLB is a fun/weird/quirky adventure of its own!
-Live Long and Prosper-
Feel free to check out my YouTube and Twitter!
