First post, by VladMar0153
Hello there.
Scalers are other parts of config have only effect on main menu of the game, as soon you launch mission, as if new instance of window opens, which ignores settings - configuration. Any solution to this? I guess, this issue has been already encountered, as problem source it seems is new instance.
Thanks in advance.
Reply 1 of 1, by jmarsh
Scalers are usually only applied when the current resolution is low (below 640x400 iirc). Add "forced" after the scaler name to override it e.g. "normal2x forced".
