First post, by FireLion
Hi all again, I'm back at it again with Top Gun: Fire at Will, and I've been thinking about this for a long time but what type of Joystick does the game use. Is there any specific one it uses. I currently use a PS4 wired controller to play it on my Macbook Air, and it works fine. I have looked in the Manual and the Quick Reference but it's not specific enough with what Joystick it uses. I would really like to know what Joystick it uses, like if i got one of the newer Joysticks, would it still work on Top Gun: Fire at Will, or would it have to be the specific one designed for the game. And also, how would I calibrate it in DOSbox, would I just plug it in to my Macbook and calibrate it through the game, or is there more to it. Please let me know.
Reply 1 of 1, by darry
FireLion wrote on 2022-11-04, 01:45:
Have a look here :
https://groups.google.com/g/comp.sys.ibm.pc.g … /m/YwP6WasTW3gJ
Excerpt :
Joystick Support
Microsoft SideWinder 3D Pro
In order to make your Microsoft SideWinder 3D Pro joystick work
with Top Gun, you first need to make sure the joystick is set
to emulate a CH FlightStick Pro. Move the "Joystick switch" on
the bottom of the stick to position 1 (the side with one dot).
When you're in the Top Gun game, choose "Setup" and then
"Joystick." Select "Choose Type" and then "CH FlightStick Pro"
from the list. Next choose "Calibrate" and follow the onscreen
directions. Top Gun supports the slider, hat switch and four
conventional buttons on the SideWinder 3D Pro joystick.
ThrustMaster Macros
Owners of ThrustMaster joystick products can find a number
of macros that will set up your joystick for Top Gun. These
macros can be found on Top Gun Disc 1 in the \JOYSTICK\TMASTER
directory. The five macros are for use with varying combinations
of ThrustMaster hardware:
QTOPGUN.B50 For use with the FLCS and TQS in combination
TOPGUN.B50 For use with the FLCS alone or with the FLCS
and WCS Mark II in combination
TOPGUN.ADV For use with the FCS and WCS Mark II in
combination
TOPGUN.MDF For use with the WCS Mark II alone
TOPGUN.M50 For use with the FLCS alone
To install these macros, copy the appropriate macro from Top
Gun Disc 1 to the directory where you have your ThrustMaster
(or CS Commander) utilities and launch your application to
download the macro to your joystick. You can then run the game
and your joystick(s) will be operational.
NOTE: When using the FLCS and TQS in combination (the
QTOPGUN.B50 macro), you must include USE NO MOUSE in the
.B50 file so that your mouse will not conflict with the TQS
trackball.
Be sure to choose the Joystick option "Programmable stick" in
the Setup area when playing the game.
The CH Throttle
On Top Gun Disc 1 in the \JOYSTICK\CH directory, there is a
template for using your CH Throttle with TOP GUN: Fire at Will.
Simply copy the file TOPGUN.KEY to the directory with your CH
Throttle software and type:
THROTTLE TOPGUN.KEY
from the DOS prompt to load the batch file. You can then run
the game and your CH Throttle will be configured properly.
…Show last 17 lines
Suncom F-15E Eagle
This update includes a SUNCOM.KEY file for the Suncom F-15E
Eagle joystick. Before loading Top Gun, you need to run
Suncom's EAGLE.EXE utility to download Top Gun's KEY file to
the Suncom joystick. Then choose "Suncom F-15E Eagle" from the
Joystick setup screen in the game and calibrate the stick. For
more information, please read the SUNCOM.TXT file.
Throttle Calibration
If you are having difficulty calibrating the throttle wheel on
your joystick, make sure you move the throttle all the way to
its maximum setting and then back down to full MIL power (100%
RPM) when the calibration routine prompts you for "full MIL
power."
