First post, by JustJulião
Guys, I spent months seeking for a similar sized baby AT case to cover this little boy I found in a former PC shop.
I even found the exact same... Hosting a full configuration for 700$ on eBay.
I tried finding an appropriate cover basing on its rear proportion (since the Baby AT format is the only standard I could identify).
My campaign being unsuccessful, I'm asking for any ideas you could have. Is 3D printing something to consider ? Is there something else I can do ?
The attachment 280123066_486602056585970_27488154045970730_n.jpg is no longer available
The attachment 280030801_372268518183905_1516950045685332223_n.jpg is no longer available
Reply 1 of 3, by rasz_pl
hit a hardware/home remodeling/renovation stores, something like home depot or lowes
first thing that comes to mind are sheets of PVC
For my main rig Iv been running same ATX case without side covers since early 2000 😀 I cut it up in multiple places since then, PSU is sitting in former 5.25 bay etc
It still has the big green DURON sticker 😀 https://commons.wikimedia.org/wiki/File:AMD_D … cessor_Logo.svg
Reply 2 of 3, by Horun
Yes I have used plexiglass sheet years ago, had to cut to fit (and then paint it as close to case color as possible if desired). Find the proper thickness might be a bit hard...looks like about 1/8" for yours ??
Your case: you would drill two small holes on the top frame then slip it in, the bottom of the case lip holds bottom and use the two screws to hold top in place.
You could try first with some packing box card board to see if it might work ok before buying a plexi sheet....
Reply 3 of 3, by JustJulião
thank you guys
