First post, by tabm0de
It might be to late as in time 😉 but I can’t find device like it anywhere, I do find one for front 3.5, but i rather have it in the back… no that’s not what she said.
I attached a picture what I’m looking for if someone knows where to get one or have a spear 😉
naa, nothing yet...
Reply 1 of 12, by PC Hoarder Patrol
tabm0de wrote on 2022-11-08, 18:30:
Easy enough to make your own with sometning like this - https://www.amazon.co.uk/PNGKNYOCN-Interface- … c/dp/B08XHW7KYC - and a M to F Molex adapter cable. Just Dremel out a blank IO plate and glue them into place.
Reply 2 of 12, by maxtherabbit
I didn't know I needed this either until you posted it, surely there are some out there
Reply 3 of 12, by darry
Interesting concept.
One would need to be careful to avoid accidental shorts . Some kind of tethered connector cover/protector for such a thing would make me feel safer.
Reply 4 of 12, by rasz_pl
Not a fan of those expose pins. 5.25 Hard Drive Enclosures are $10-20
Reply 5 of 12, by tabm0de
rasz_pl wrote on 2022-11-09, 10:20:
That might be true, i rather test devices directly connected to my pc. i do have harddrive enclosures but they aren't really compliant with other ide devices 😉
naa, nothing yet...
Reply 6 of 12, by konc
I'm not grasping the use or benefit of this device, what can someone use it for? In my mind if I need to connect an IDE cable and molex power cable anyway, I might as well have such cables hanging out of the box. Cleaner look when nothing is connected maybe?
Reply 7 of 12, by tabm0de
konc wrote on 2022-11-09, 10:51:
Well is more for convenience when the need to test something, sadly it’s like 1% of all at cases that do allow to open one side, rest you need to remove the hole cover, as my office is small I rather not need to remove cover form tower if I just can connect two cables 😉
naa, nothing yet...
Reply 8 of 12, by konc
tabm0de wrote on 2022-11-09, 11:48:
Oh this I get it, not having to open the case is a very valid reason. But what's the benefit of it when compared to IDE+molex cables hanging from the back of the case? I can only imaging tidiness when not in use, which is also a valid reason of course.
Reply 9 of 12, by rasz_pl
tabm0de wrote on 2022-11-09, 10:27:
You can sacrifice mod one of the caddies to be a passthru molex/40pin cable. No exposed pins and easier access from the front.
Reply 10 of 12, by weedeewee
There are also internal hard drive caddys though you will be limited to 3"5 or 2"5 drives only.
I'm not quickly finding any references.
Someone else will likely know what I mean and have more luck searching it with the correct terms. 😀
edit: added photo, search terms "3.5 IDE PATA ATA hdd dock rack tray caddy mobile for 5.25 slot"
Do not ask Why !
Reply 11 of 12, by tabm0de
weedeewee wrote on 2022-11-09, 17:13:
There are also internal hard drive caddys though you will be limited to 3"5 or 2"5 drives only. I'm not quickly finding any refe […]
Ye, i have one of those , sadly they are hard to test example zip drive or cdroms in 😉
naa, nothing yet...
