First post, by amatrix85
Good daytime,
Does anybody have a driver for SCSI CD changer from Nakamichi? One from VOGONS driver library is only for IDE drives.
The problem with standard driver is the changer recognizes only as 5 independent CD-ROM drives with 5 different letters, but I need to have one letter with contents of the loaded CD inside.
Reply 1 of 4, by weedeewee
as far as I know those drives identify themselves to the system as several drives, since each drive letter will correspond to one of the chosen cdtrays.
This is also one of the more annoying features of those drives when you accidentally access two cds at the same time it will be busy accessing one, then the other, then the one, etc... until the access has finished.
If the default aspicd.sys doesn't work then I'm fairly certain you'll be out of luck. Though I could be mistaken since I only have the ide version and never had a scsi one.
Do not ask Why !
Reply 2 of 4, by PC Hoarder Patrol
amatrix85 wrote on 2022-11-09, 11:25:
Good daytime,
These are the SCSI drivers listed on the old Nakamichi archive
The attachment mj516s.exe is no longer available
"Important: To extract the setup files correctly you must run the compressed EXE file with the -d option. Example: MJ516.EXE -d
This is necessary to create the proper directory structure.
Reply 3 of 4, by snugis
Hello guys, i have question about this funny cd changer.
I got one with IDE connector but i can access only disc 1 from windows (xp or 98) drivers above does not help me with this problem.
What im doing wrong?
Reply 4 of 4, by amatrix85
snugis wrote on 2022-12-08, 23:45:
They won't. They're only for SCSI CD. You have right opposite problem than I had. Fortunately. drivers for IDE CD changer are not quite rare. https://www.driverguide.com/driver/detail.php … driverid=386809 - here they are, for example. http://www.vogonsdrivers.com/getfile.php?file … menustate=58,55 - they present even in Vogons library.
