First post, by haxor
Hello,
i am currently trying to fix a Intel batman's revenge mainboard. I've fixed some minor problems but dont know howto proceed now. So this is the status right now:
The board powers on, CPU is getting warm (as well as the chipset). POST card is not displaying any codes but shows 12/5V OK (also checked via multimeter). No beeps.
OSC is fine at 14.3 Mhz, Clock on ISA bus at 7.6 Mhz. The CPU is getting clock (60Mhz) from the chipset. (Verified by scope).
The RESET line lights up on boot for a second (on the POS T card) but afterwards i cant trigger it - i.e. pressing the reset button wont make it light up. The reset line must have some issue.
The FRAME led on the POST card is constantly lit - afaik it should only be lit when there is bus activity which should be random and not lit all the time?
The previous owner desoldered the dallas 12887 (which was probably empty) but did quite a mess with bad solder joints. I didnt touch this area yet, only checked if the socket
had continuity to somewhere near (74L chips). Seems they have contact except for pin A3 - no idea where its going or if its connected at all. The traces are buried below the socket
and i'd have to desolder the socket to find out where its going. Tried area around it but couldnt find anything where it connects to. Anyone know if this is used at all?
I've read that the batman revenge boards are quite problematic about the RTC and wont boot up without one. (which i have tested, everything stays the same).
Unfortunately the bios chip is soldered to the board. I'd like to only desolder it if neccessary (to prevent stress to the board). I am not sure if above problems could be caused by a missing/defective bios.
The mainboard however provides a "recovery" option (using some write protected 8kb bootblock) for the bios by setting a jumper - which i have tried but doesnt change anything.
So i am a bit puzzled here. Any hints?
Reply 1 of 7, by rasz_pl
haxor wrote on 2022-11-09, 23:07:
The previous owner desoldered the dallas 12887 (which was probably empty) but did quite a mess with bad solder joints. I didnt touch this area yet, only checked if the socket had continuity to somewhere near (74L chips). Seems they have contact except for pin A3 - no idea where its going or if its connected at all. The traces are buried below the socket and i'd have to desolder the socket to find out where its going. Tried area around it but couldnt find anything where it connects to.
I can tell you BIOS might not want to progress without/with malfunctioning dallas chip, but no post codes means your bios doesnt execute at all.
scope bios cip select/ output enable pins, address and data pins, see if any data is read from EPROM at all
Reply 2 of 7, by TheMobRules
Here’s a photo I took when I desoldered the Dallas chip from my Batman’s Revenge board. Hope it helps!!
The attachment 3D1EDF35-42D4-4B7C-AD41-0BFF856475B6.jpeg is no longer available
Reply 3 of 7, by haxor
rasz_pl wrote on 2022-11-10, 04:38:
I've scoped all pins from the eprom. Chip select and output enable are high once powered up and stay high. The data and address pins do all show signals (on some i see 60 Mhz signals on others different).
How would i know that there is actual read activity to/from the eprom?
Reply 4 of 7, by haxor
TheMobRules wrote on 2022-11-10, 09:52:
Thanks alot! This helped to check the traces - they are fine. So i can outrule the dallas as the culprit (for now).
Reply 5 of 7, by rasz_pl
haxor wrote on 2022-11-10, 11:36:
pins 20 and 22 of BIOS _must_ both be low at the same time for successful bios read
Reply 6 of 7, by haxor
rasz_pl wrote on 2022-11-10, 13:18:
are you sure? The board has a intel n28f001bx chip (plcc 32). PIN 20 on that chip is D6 and 22 would be CE (chip enable).
Just checked the datasheet and it appears both CE and OE should be low for successfull operation/execution. I assume you mean these two?
So there must be something driving these high...any idea where to look for?
Reply 7 of 7, by rasz_pl
haxor wrote on 2022-11-10, 20:11:
ah yes, different footprint, 22 and 24
they are driven high by default, and both go low only when chipset decodes memory read from BIOS address space access
you can look at maybe similar design in intel 430HX reference design https://usermanual.wiki/Document/intel82430hx … .1819793331.pdf
mercury chipset https://pdf1.alldatasheet.com/datasheet-pdf/v … EL/82378ZB.html doent have dedicated romCS output? seems page 114 shows 74F138 decodes and generates this signal
>This register enables/disables accesses to the RTC, keyboard controller, floppy disk controller, IDE, and BIOSlocations E0000–EFFFFh and FFF80000–FFFDFFFFh. Disabling any of these bits prevents the encoded chipselect bits (ECSADDR[2:0]) and Utility Bus transceiver control signal (UBUSOE#) for that device from beinggenerated
