First post, by flynth
I'm in a process of setting up a 386sx-25 system. However I'm having a weird issue. The system sometimes runs fine, other times it boots in mono. One just has to try many times then to get color again.
My motherboard has a mono/color jumper. I replaced it. I also tried scratching through any possible corrosion on the pins by repeatedly removing and installing the jumper. This made no difference.
The video card is trident 9000. It has no mono/color selection. It does however have one jumper I'm not sure how works. It is the "bios auto detect configuration" jumper. Could it being on enable have anything to do with this?
I tried wiggling the monitor cable etc, with o difference.
So I wonder if I have a dodgy video card, or a motherboard that somehow thinks it is supposed to output mono instead of color. Unfortunately I haven't got another isa video card to test here.
Reply 1 of 8, by zyga64
Problems with 8-bit TVGA9000 based ISA video card
TLDR:
Grzyb wrote on 2020-04-17, 02:03:
TVGA9000i pin 46 (MONITOR) is connected to the VGA connector pin 12 (Monitor ID Bit 1) […]
So, it works as designed.
WIth DDC2, pin 12 is serial I²C data, ie. sometimes 0, sometimes 1.
If you want a DDC2 monitor always detected as color, you need to disconnect that signal.
If you don't want to desolder this pin, you have to use Trident's smonitor.exe utility.
8088@8 /640k /TVGA9000C /ALS100+TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 2 of 8, by flynth
zyga64 wrote on 2022-11-11, 13:52:
Problems with 8-bit TVGA9000 based ISA video card […]
TLDR:
Cool, thank you for this. I really thought I have some hardware fault. I was going to be washing the motherboard as a next step...
Reply 3 of 8, by MarkP
I have a Zenith that does this if the monitor is still switched off when firing it up and then switch the monitor on.
Reply 4 of 8, by maxtherabbit
You don't necessarily need to desolder, you can just cut the trace - or even add a pull up/down depending which logical state the chip looks at as color.
Many of the trident 8900 cards I've worked with even have a jumper to override the monitor detect
Reply 5 of 8, by Namrok
Recently I addressed this in one of my own systems by just getting a Male to Female VGA Port Saver/Adapter, and snipping pin 12 off the male end. Makes for an easily reversible fix.
Win95/DOS 7.1 - P233 MMX (@2.5 x 100 FSB), Diamond Viper V330 AGP, SB16 CT2800
Win98 - K6-2+ 500, GF2 MX, SB AWE 64 CT4500, SBLive CT4780
Win98 - Pentium III 1000, GF2 GTS, SBLive CT4760
WinXP - Athlon 64 3200+, GF 7800 GS, Audigy 2 ZS
Reply 8 of 8, by Horun
MarkP wrote on 2022-11-14, 15:03:
I have one that does same, also have one that does opposite. 🤣 yeah it is a real thing 😀
