First post, by Tiemen
Just wanted to show off my retro pc gaming project I worked on for a long time.
113.9 KiB
Goal was to make a pc that could run all the games from when I was young (I still am 😛), age 5-15 (till the end of 2000). There are about 200+ games I've played in that period, and I installed each and every on of them. Games range from 1982 till 2000.
129.15 KiB
This is the setup:
Tualatin 1400S
Voodoo 3 3000
QDI Advance 10T
512 MB pc133 Ram
Yamaha ymf719-s
Dreamblaster S2
Big internal pc speaker 0.5 Watt
Crucial MX500 250GB SSD
Delock IDE sata converter
Corsair RM750X
3x Cooltek Silent 120mm
2x Cooltek Silent 140mm
Spire WhisperRock V
Sharkoon M25-V
New Old Stock CD Drive
New Old Stock Floppy Drive
Fan Splitter
Round IDE and Round Floppy cable
3DFX Sticker
Windows 98 SE
Network card
Logitech X-230
Samsung Syncmaster 950P CRT
Installed literally every game I played from age 5-15.
247.74 KiB
At first I also had a Voodoo5 5500 and a Voodoo2 12 mb. The voodoo5 5500 broke, luckily, otherwise I would have never found out that the voodoo3 3000 was way more perfect for my needs. It runs all my games flawlessly, and even the dos games in 3DFX (except Champions League 96-97). I auctioned the Voodoo5 5500 on Ebay for 250 euro (can you believe that? bought it for the same price 2,5 years back) and I'm still trying to sell the voodoo2.
I also had an audigy 2zs in it at first, but that thing caused nothing but problems and it was a pain in the ass with the audio splitter. I also don't hear the difference between that one and the Isa card I have in it.
I made a real fridge out of the pc. The Cooltek Silent has really good airflow. When I had the Voodoo5 still in it, the cpu was idle 32 degrees celcius, and the system 28. Now, the cpu (a Tualatin!) is 24 degrees celsius idle, and the system 19 degrees celsius (see picture)! After it has been on for 2 hours it's cpu 26 and system 21. The components where in a closed retro case before this, with really bad airflow, and the cpu was 62 degrees idle.
356.2 KiB
Only 2 games didn't work. Ark of Time (gpu too new, some Vesa problem), and South Park, for some strange reason. (edit: South Park works now, it was just copy protection, needed a patch).
Well, hope you like it 🙂
Thanks for the knowledge you guys provided and big thanks to the SETYMF tiido guy for the Yamaha card driver. Program saved my ass 😁.
131.16 KiB
Reply 1 of 19, by Duffman
@Tiemen
Very Nice!
Just a bit of a heads up with your 250GB SSD, make sure to install rloew's PATCH137 or PATCH1TB so you don't encounter wrap-around corruption past the 137GB barrier and lose everything on the drive.
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 3 of 19, by Tiemen
Duffman wrote on 2022-11-18, 06:33:
@Tiemen
Very Nice!
I made a Partion in windows 98 that gives me a 128 GB harddisk. I will never have more on that disk. Do you think it's still necessary to install it?
Reply 4 of 19, by Duffman
@tiemen
I believe so yeah, Someone please correct me if I'm mistaken, it's something to do with how win98 handles drives larger than 137GB is broken and needs patching, I recall XP RTM had a similar issue that wasn't fixed until XP SP1.
Microsoft never released an official patch for win98 though, so we have to use rloew's - you can find it here link: https://rloewelectronics.com/distribute/TBPLUS/3.0/PATCH/
CPU: Ryzen 9 5950X
Reply 5 of 19, by Tiemen
Duffman wrote on 2022-11-18, 14:58:
@tiemen
Thanks, I'll check it out!
Reply 8 of 19, by mrzmaster
That QDI Advance 10T board is so neat, supporting the fastest Tualatin but also has an ISA slot. When I was building my Tualatin system, I originally wanted to go with the Advance 10T but bought 2 bad ones in a row, gave up and bought a TUSL2-C. So I ended up having to build another slot 1 rig with ISA for pure DOS stuff. I ain't mad, but so nice to see a rig that has the best of both worlds. 😀
Reply 9 of 19, by chinny22
"The voodoo5 5500 broke, luckily"
I don't think anyone else has said, ever! 🤣
I like the nice simple case design and as you said the cooling is so much better then ones from 20 years ago.
I'd still want EAX support but if it's hassle free your after then just the Yamaha card is fine, plenty of motherboards used similar YMF for onboard sound during this time.
Reply 13 of 19, by iraito
Dayum that's one hell of a tualatin monster, would you entertain a fellow nerd?
Can you try and run deus ex (latest) on that PC at max detail at 1024x768? i'm not fully satisfied with the performances of my own PIII system regarding deus ex and since i'm planning to add an MX300 in it as a companion piece to the SB i want to check if i need to upgrade something.
If you wanna check a blue ball playing retro PC games
MIDI Devices: RA-50 (modded to MT-32) SC-55
Reply 14 of 19, by Bruno128
iraito wrote on 2023-02-06, 16:16:
I'm afraid that is a bit too much for the V3-3000.
Tiemen, your system is so fine, greets! I am totally with you that if there is an ISA slot forget the Audigy just use it.
Now playing: Red Faction on 2003 Acrylic build
SBEMU compatibility reports
Reply 15 of 19, by TrashPanda
Bruno128 wrote on 2023-02-07, 10:52:
Yeah max details @ 1024x768 is the issue, might handle it at 800x600 however.
I remember running this game at 1024x768 with max details on a Voodoo2 SLI setup back in the day and it ran it beautifully using GLIDE.
Reply 16 of 19, by Joseph_Joestar
TrashPanda wrote on 2023-02-07, 11:02:
Yeah 1024x768 is the issue, might handle it at 800x600 however.
Agreed. I recently replayed Deus Ex on an AthlonXP 1700+ and a Voodoo 3 2000 and it ran pretty good at 800x600. I was getting 60+ FPS indoors and 40-50 FPS in large, outdoor areas.
One thing to note is that the first level (Liberty Island) is the most demanding map of them all. Literally every other level in game will have better frame rates.
Reply 17 of 19, by TrashPanda
Joseph_Joestar wrote on 2023-02-07, 11:08:
I would have thought the V3-3k was on par with a Voodoo2 SLI setup but I guess it doesn't quite have the grunt. I guess it does demonstrate just how powerful the 12Mb Voodoo2 actually was back in the day and how much it scared the likes of ATI and nVidia into stepping up their game. That said . .the TnT was one hell of a card and really stuck it to 3DFX, sad they never had a chance to reply with the Rampage core.
Reply 18 of 19, by iraito
I was curious mostly for the CPU, truth is that my GeForce 3 system has something like 25fps in large areas, i think a voodoo 3 can run the game pretty well with a strong CPU like the best tualatin or a P4/athlon XP.
Reply 19 of 19, by Joseph_Joestar
iraito wrote on 2023-02-07, 16:50:
I can tell you that I get 60+ FPS on Liberty Island at 1280x1024 with an Athlon64 3400+ paired with a GeForce FX 5900XT.
Certain outdoor maps in Deus Ex are very demanding on the CPU.
