First post, by Allanar
Hello guys, can you please help me?
I need driver for this card,or at least a sound driver.
Thanks
Reply 1 of 6, by darry
Allanar wrote on 2022-11-23, 14:38:
Thanks
It looks like a card from the Intel ProShare Conferencing Video System 200 ( circa 1994 ).
http://www.itbiz.com/dominio/video010.htm
What do you hope/expect to do with it ?
Reply 2 of 6, by Allanar
darry wrote on 2022-11-23, 15:04:
It looks like a card from the Intel ProShare Conferencing Video System 200 ( circa 1994 ). http://www.itbiz.com/dominio/video01 […]
Thanks
the card is functional, but I need a working sound
Reply 4 of 6, by darry
gerwin wrote on 2022-11-24, 01:54:
Allanar wrote on 2022-11-23, 20:21:
On the photo: CS4215 is a sound chip.
Maybe a driver for another CS4215 based soundcard works? example: http://ohlandl.ipv7.net/sound/Audiovation.html
The CS4215 is purely a codec, it has no ISA interface, so trying drivers for another card is very unlikely to work.
It is also unclear whether this device actual has drivers that allow exposing itself to the operating system (Windows) as a sound card. Any kind of DOS (Sound Blaster/Adlib) compatibility is quite unlikely.
https://pdf1.alldatasheet.com/datasheet-pdf/v … /CS4215-KL.html
Reply 5 of 6, by darry
Thanks
In what way is it functional? Have you been able to use it for video conferencing? Is videoconferencing working except for sound ?
EDIT :
To be clearer, there is no guarantee that this was ever designed to work as a standalone sound card, but information is scarce so I can't confirm or infirm. Good luck!
#hardware specifications
https://web.archive.org/web/19991008070926/ht … cing/8186.HTM#2
#drivers
https://web.archive.org/web/19991013014647/ht … ng/software.htm
# frequently asked questions
https://web.archive.org/web/19991018191758/ht … encing/1746.htm
Reply 6 of 6, by Warlord
it probably doesn't work outside of using the intel proshare software for video confrencing. if it does i doubt its good for gaming.
