First post, by Martin85
Does anybody have a manual for this monitor? It has a switch on the back labeled as S.O.G. and TTL
what is it for? Googling around give nothing really... 🤔
As far as I tested the monitor it works ok.
Reply 1 of 5, by sdz
Sync on green perhaps?
Reply 2 of 5, by pentiumspeed
Yes, sync on green. Which means sync timing is inline between green video signal bursts. Not common in PC but common on specialized computers like SGI, Sun, etc.
Cheers,
Great Northern aka Canada.
Reply 3 of 5, by zyga64
TTL sounds like digital RGB, so maybe EGA/CGA is supported ?
Does it have a DB9 connector on the back ?
Nope. Looks like this is VGA only monitor: https://www.download.p4c.philips.com/files/1/ … 0c_dpi_eng.html
Last paragraph is about sync-on-green.
8088@8 /640k /TVGA9000C /TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 4 of 5, by Martin85
So if I understand correctly... TTL shoudld be used always, with monochrome or color source?
I had some weird stuff going on while testing the system yesterday. But have to check first on other monitors (lcd and crt) before I jump to conclusions.
Reply 5 of 5, by Ryccardo
Yes BUT you need normal analog video and not MDA/CGA/EGA, it seems that TTL refers to the sync signals (which is correct but not the common definition of the word, when it comes to video inputs);
if you know how to use a BNC computer monitor with that specific source, and it would use 3 cables, select SOG, if it uses 4 or 5 cables (as with standard VGA and above) select TTL 😀
