First post, by keenerb
I've got a Tandy 1000 and some other vintage beige box hardware sitting on my office desk for downtime tinkering. I'm concerned that it will begin to yellow now that it's near this large window.
I have some semi-dark curtains but a fair amount of light passes through them, and I often will have the curtains open completely.
What's my best option? Blackout curtains and never look out the window? Is there a UV protective film that can help keep this hardware from yellowing?
Reply 1 of 4, by The Serpent Rider
Does your window is located on the sunny side or only receiving reflected light? Geographical location is also important. For example, if you live in Finland, I wouldn't bother much.
Reply 2 of 4, by Ryccardo
All glass except quartz and crystal is a pretty good UV filter, that's why those (aka lens protectors) are one of the cheapest camera accessories and part of why halogen lamps have a second layer 😀
Reply 3 of 4, by X86
I have seen people tint windows on a house like you would a car window. In my game room I had a heavy duty banner made as a window covering to block light. Was from a seller on Amazon. Just sent them the image I wanted on it.
The attachment PXL_20220913_232443954.jpg is no longer available
The attachment PXL_20220914_000333332.jpg is no longer available
Reply 4 of 4, by Matchstick
UV is not the cause of yellowing.
Heat is the cause. This is why yellowing still occurs in a box in the dark of an attic.
Note sunlight is also a source of heat, not just UV.
