First post, by assortedkingdede
I got a PCI Realtek RTL8139D windows won't detect the card. Installing drivers does nothing. The card seems to power up but shows no activity (The LED's on it are lit). What should I do? Thanks!
Reply 1 of 11, by assortedkingdede
Issue solved but now windows wants to tell me on startup that I am missing a bunch of .vxd files that I don't need. How do I get rid of this? Thanks!
Reply 2 of 11, by Disruptor
Do you have "ifshlp.sys" in your config.sys and "net start" in your autoexec.bat ? (If it is Windows for Workgroups 3.11)
Reply 3 of 11, by dionb
How was issue solved? And what motherboard are you trying to install it on?
One thing to be aware of is that most RTL8139C and D cards require PCI 2.2 and 3.3V, which is not available on many older (BX-era and before) boards.
Reply 4 of 11, by assortedkingdede
dionb wrote on 2022-12-01, 07:48:
Tried a different driver and repositioned the card as well as rebooting the computer. I was using a P6BAP-A+ motherboard.
Reply 5 of 11, by dionb
assortedkingdede wrote on 2022-12-02, 02:31:
So a Via ApolloPro133 chipset - Via's first PCI 2.2 chipset. So that's not the issue.
Reply 6 of 11, by dormcat
Didn't know that. I've got 8139 cards on 430FX and TX motherboards and they work fine even under Windows 3.1.
Reply 7 of 11, by majestyk
assortedkingdede wrote on 2022-12-01, 03:53:
If this is WIN98 there are a lot of howtos for that online. You have to extract the missing files from CD and copy them into the system folder.
Reply 8 of 11, by Gmlb256
This sometimes happens when installing the drivers for the NIC. Reinstalling "Client for Microsoft Network" usually fixes that.
Interesting, I used one of these Realtek NIC on a motherboard with 440ZX chipset and it worked fine.
Reply 9 of 11, by drosse1meyer
Gmlb256 wrote on 2022-12-02, 15:05:
This sometimes happens when installing the drivers for the NIC. Reinstalling "Client for Microsoft Network" feature usually fixe […]
This sometimes happens when installing the drivers for the NIC. Reinstalling "Client for Microsoft Network" feature usually fixes that.
Yea windows *should* prompt for the install disk when installing the nic which will put the proper files in place. I always copy the install discs cabs to a local folder because this gets way too annoying in Win9x.
Reply 10 of 11, by dionb
dormcat wrote on 2022-12-02, 14:55:
Sure it wasn't RTL8139B? They always work with 5V-only. It's entirely possible that the C and D cards are made to work with only 5V (in fact, PCI spec says they must be backwards compatible), but they tend to be on cheap PCBs that don't support htat.
Reply 11 of 11, by dormcat
dionb wrote on 2022-12-02, 19:44:
Just confirmed: it's RTL8139C on Asus TXP4:
The attachment IMG_20221203_071652.jpg is no longer available
Couldn't find any details on PCI slots of TXP4, though. IIRC another NIC of the same model is on a Pentium 120 build (430FX chipset) and worked fine as well, but the machine is not with me at this moment.
