First post, by Kahenraz
I wanted to find a simple way to test FM and digital sound without having to start up a game. I found a great test program from Adlib for FM, and a program "plany" which can play a WAV file for verifying Sound Blaster digital sound. Of course, I needed a sound clip to play, and I couldn't think of anything better than "Your sound card works perfectly!" from the Warcraft 2 setup.
I would love to hear how other people test their sound cards. My normal go-to is Duke Nukem 3D setup, but in this case I wanted something that I could quickly run from the command line.
Reply 1 of 2, by Shponglefan
I test my sound cards on the basis of whatever I am using it for. Typically this will be a battery of games and/or music players. I perform different tests for different types of audio output (digital audio, MIDI playback, CD-audio, etc.).
I've found there is no single test that indicates how well a card may perform under all scenarios. In some cases, cards may perform differently or not even work at all with certain software / games.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 2 of 2, by Tiido
My go-to test has been setup of Duke3D, it can make sound with SB, FM and MPU without too much fuss and can hint to possible problems too (DMA or IRQ problem).
