First post, by Blavius
I have an IBM server from 2003 sitting in the garage with a Xeon Prestonia in it. Looking for a next project, I decided to resurrect this old beast. The motherboard has two sockets, but only one is filled, so I hunted down a VRM and identical Xeon on ebay. For peanuts really, the CPU was just $9. Don't have the parts it in yet, but in figuring out what processor to get I noticed that is basically an early netburst pentium 4.
This put me on a whole other train of thought. In general there are consumer (Pentium) and professional (Pentium Pro/Xeon) processors. Motherboards with dual sockets seemed to exist for both up to some point. Like, I've seen examples of dual pentium, pentium II and pentium III on this forum. Then later on, in 2005, we got the pentium D and I assume the need for dual socket boards for consumers disappeared. But what about the early pentium 4 years, pre-hyperthreading (2000-2002)? Maybe I'm just terrible at searching, but I didn't find pictures or mentions of dual pentium 4 anywhere. So, just out of curiosity:
-Do dual pentium 4 motherboards exist? If so, do you have experience with them? If no, why do you think that's the case?
Reply 1 of 16, by red-ray
Blavius wrote on 2022-12-03, 10:04:
No and I assume Intel did this to increase the sales on Xeons
Reply 2 of 16, by The Serpent Rider
Probably something related to the numbers of pins. Socket 603/604 had more pins for a reason. And well yeah, market segmentation is a thing - lowest end workstation/server motherboards had single Socket 478, just like regular desktop.
Reply 3 of 16, by Errius
I have a Pentium 4 rig running a SL8PZ and a dual Xeon rig with a couple of SL8P3's. What's interesting about this is that both chips have the same CPUID/stepping (0F4Ah/R0). So it's basically the same CPU in both cases but just in a different packaging (LGA775 vs. S604)
"AI Requires Proof That You Are Human"
Reply 4 of 16, by Blavius
Errius wrote on 2022-12-03, 13:01:
That's very interesting, that supports the idea of forced market segmentation. Perhaps there are some pins required to enable SMP that are not present on the pentium 4 package, so there is no way to put more than one by design.
Earlier this was not the case, as wikipedia (sorry) states: "When first introduced, Slot 1 Pentium IIs were intended to replace the Pentium and Pentium Pro processors in the home, desktop, and low-end symmetric multiprocessing (SMP) markets. The Pentium II Xeon, which was aimed at multiprocessor workstations and servers, was largely similar to the ordinary Pentium II, being based on the same P6 Deschutes core, differing by offering the choice of L2 cache capacity of 1024 or 2048 KB besides 512 KB". Seems like for pentium 4 they decides 'low-end symmetric multiprocessing' also belonged under the multiprocessor umbrella.
Reply 5 of 16, by dionb
It's just marketing.
Since P54 (Socket 5), Intel has designed CPUs with native SMP. They have however chosen whether to enable that functionality on a per CPU and per chipset basis, depending on what they wanted to sell to whom. You see that more clearly when you look at architecture code names rather than commercial names.
P4 CPUs were all based on the Netburst architecture, which most definitely supported SMP. Intel chose to completely separate the marketing of the SMP-disabled CPUs (called "Pentium 4") from the SMP-enabled CPUs (called "Xeon") despite the chips being otherwise virtually identical - as Errius points out, the CPUIDs and steppings were identical between Willamette vs Foster, Northwood vs Prestonia and Prescott vs Nocona. Prestonia did have HT support where Northwood did not, but this was not different silicon, just functionality enabled or not.
Intel did get a bit more creative in the high end, with Xeon MP (supporting 4-way SMP) having more cache by default, and there also being bigger-cache Xeon DP Gallatin CPUs - which again got re-used as non-SMP Pentium 4 Extreme Edition.
The restriction of P4 to non-SMP vs Xeon for SMP was for purely commercial reasons, on par with things like multiplier locks, disabled cache and technically unnecessary socket changes. So if you want to follow Intel's marketing, "P4" did not support SMP, but if you look from a technical point of view, Netburst most definitely did and only lacked it where intentionally disabled.
As multi-core became more common, this distinction was even more artificially moved from SMP vs non-SMP to SMP-in-single-socket vs SMP-over-multiple-sockets, and multi-socket designs were relegated to more niche high-end applications, as for all concerned multiple cores on a single die were cheaper, easier and generally preferable to the same number of cores on separate sockets.
Reply 6 of 16, by Scraphoarder
By looks of the netburst Xeons it looks like they slapped an P4 on top on an interposer. Have saved some Xeons after we scrapped some HP Proliant DL380 G3 servers and im curious if its possible to desolder/remove the CPU core from the s603/4 pcb.
Reply 7 of 16, by Errius
I wonder what was the retail price difference between these otherwise identical CPUs
Reply 8 of 16, by Sphere478
I wonder if you could maybe take a 603/604 cpu and put a bga 478 socket on it? Then put whatever pentium 4 you had laying around on it?
Sphere's PCB projects.
Reply 9 of 16, by Blavius
Thanks for the detailed writeup dion, very interesting to read.
Sphere478 wrote on 2022-12-04, 04:25:
Heheh 😀 I guess you could, if the socket doesn't check for the missing pins. However, unless all extra pins are dummies, I doubt you'll be able to build a dual P4 this way so it's kinda pointless as Xeons (at least these ones) are cheap.
Reply 10 of 16, by majestyk
dionb wrote on 2022-12-03, 14:35:
Didn´t late Northwoods support HT?
Reply 11 of 16, by Sphere478
Yes
Blavius wrote on 2022-12-05, 18:19:
Dual extreme editions!
Reply 12 of 16, by acl
I can only think about one later "consumer oriented" multi socket system.
Intel SkullTrail in 2008.
But it's very high end.
And mostly like a server board (Dual socket 771 Core2Extreme with FBDIMM required)
Reply 14 of 16, by H3nrik V!
Sphere478 wrote on 2022-12-05, 20:58:
I really want a 604 to 478 interposer now 🤣
Someone do this 🤣
Aren't you the one doing that? 🤣
Reply 16 of 16, by Disruptor
Motherboards not.
But the Pentium D is special:
Smithfield based Pentium D's use 90µm process and have one package with one die with 2 cores that share the FSB that also goes to the motherboard.
Presler based Pentium D's use 65 µm pcoress and have one package with two dies that share fhe FSB that also goes to the motherboard.
code name, process, cores, threads, remark
Pentium 4, Prescott, 90µm, 1, 2 (hyperthreading)
Xeon, Nocona (no XD Bit) + Cranford + Irwindale (bigger L2), 90 µm, 1, 2 (hyperthreading)
Pentium D, Smithfield, 90µm, 2, 2 (2 cores on a single die; hyperthreading disabled)
Xeon, Paxville, 90 µm, 2, 4 (2 cores on a single die; hyperthreading)
Pentium 4, Cedar Mill, 65 µm, 1, 2 (hyperthreading)
Pentium D, Presler, 65 µm, 2, 2 (2 dies on a single package; hyperthreading disabled)
Xeon, Paxville MP, 65 µm, 2, 2 (2 dies on a single package; hyperthreading)
