First post, by flynth
I've been searching and searching, but unable to find any user's manual for the Ulsi Systems 3C87-40 coprocessor. As is is not obvious which orientation to install them in (and I broke one 387sx before) I thought to ask if anyone has any links/documents for those?
I found a picture of my motherboard on thertroweb showing the coprocessor installed "sideways" (bottom towards ram), but this is just one picture and I really don't want to break this chip.
Here is the chip:
252.18 KiB
Here is the motherboard socket:
453.03 KiB
This motherboard is a Data Expert 367c Rev 1.
Reply 1 of 6, by Grzyb
416.84 KiB
717.01 KiB
Nie tylko, jak widzicie, w tym trudność, że nie zdołacie wejść na moją górę, lecz i w tym, że ja do was cały zejść nie mogę, gdyż schodząc, gubię po drodze to, co miałem donieść.
Reply 2 of 6, by vstrakh
My mobo has different orientation, but socket's pin 1 is clearly marked on the silkscreen. Same bump for pin 1 on FPU.
377.82 KiB
Reply 3 of 6, by Horun
https://theretroweb.com/motherboards/s/dataexpert-367c
https://theretroweb.com/motherboard/image/367 … bd497314294.jpg
Has a 386 socket with 486DLC but same IIT 3c87...
Reply 6 of 6, by Horun
flynth wrote on 2022-12-04, 00:43:
Great. Thank you all. I installed it and it works fine 😀
Great ! Glad you got it working.
