Cystal clock 40mhz 386
First post, by vacatedboat
Ive had this motherboard for many years but just noticed the on board crystal is 40mhz but my processor is the 386dx 40. In my crazy mind should i have been putting an 80hz crystal in?
Ive only just got around to benchtesting this machine and the retroweb finally has an entry!
https://theretroweb.com/motherboards/s/copam-c3404#downloads
In a bios setting i set cpu speed to high. The system test in dosbench mark reports 19mhz?
And also i just finished making an external battery coin cell so i will get rid of that barrel!
Thanks heaps
Reply 1 of 5, by Disruptor
Well, all 386DX I know need CLK2 input.
That means that your OSCillator needs double clock frequency: 80 MHz for 40 MHz operation frequency.
Reply 2 of 5, by AlexZ
Isn't there a jumper for this? I remember my 386DX board had a jumper on it where I could select 33/40 Mhz. It looks like one of compact late 386 boards, so it seems unlikely it would only support 386 20Mhz.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 3 of 5, by vacatedboat
AlexZ wrote on 2022-12-04, 09:54:
Checking the board thoroughly and also the retroweb tells me there are very few jumpers to alter.
So i hope i can source an 80mhz xtal easily and put it in. Thanks
Reply 4 of 5, by AlexZ
On close inspection of picture of your board and the one on theretroweb for identical board it really seems they have 80Mhz crystal while you got 40Mhz. If you get to replace the crystal it may be worth getting both 80Mhz and 90Mhz one for a small overclock. For higher OC cache faster than 20ns and 60ns memory will likely be needed. Also fit it with 256Kb cache.
Reply 5 of 5, by GigAHerZ
AlexZ wrote on 2022-12-04, 18:03:
I can confirm the 90MHz crystal idea. I'm running my 386DX at 45MHz on M321 motherboard with 90MHz crystal. Love it!
I also bought 100MHz crystal, but it seems to be just dead. Maybe there are some different types of 4-legged crystals? (I don't have oscilloscope to confirm)
A little about software engineering: https://byteaether.github.io/
