First post, by Kahenraz
I bought an ESS Audio drive ES1868F that looked a little dirty in the photos, which is pretty common for parts of this vintage. After washing it on the sink however, I discovered that it wasn't dirt but some very thick corrosion. The damage is isolated to the back of the board, and only on a few parts; mostly passive, so I expected that it would still work.
After a bit of driver searching and setup, I can confirm that it does indeed still work. But there is a definite hum from it to my speakers when the volume is raised to a moderate level, and it is clearly audible when the volume is turned up to the maximum. I found that the hum is coming from the ground plane, as the hum occurs just the same if I simply touch the speaker plug to the PCI bracket instead of plugging it into the socket.
I was able to work around this issue by using a ground loop isolator between the card and the speakers. It wasn't just diminished either; it was completely gone.
My question is whether this hum is a fault in the design of the board itself or whether this is related to the corrosion. I'm thinking about trying to scrape some of it off, but I'm not sure if I want to replace any of the parts if it's working as it is, unless there is something I can do to I improve on the hum, or find a way to remove the need for a ground loop isolator.
Here are some photos of the card and the damage.
197.55 KiB
66.58 KiB
119.32 KiB
Reply 1 of 5, by Kahenraz
Some more close up photos from my microscope.
169.59 KiB
128.21 KiB
164.25 KiB
Reply 2 of 5, by Bancho
I have this exact card and it's noisy as shit. I don't know if its possible to bypass the amp via jumpers, or if its possible with a hardware mod? It is a nice card just a shame the output is so noisy! I didn't try anything with the ground plane like you did
Reply 3 of 5, by Kahenraz
Other than the noise, it's a great card. The General MIDI implementation is pretty good, but I get some weird sounds with some of my test songs, like one of the instruments is wrong. I'll have to make some recordings to share.
This is the product that I bought on eBay. It worked perfectly and solved the annoying hum I was getting. You can try it out with yours.
Search eBay for "ground loop isolator".
76.51 KiB
Reply 4 of 5, by Bancho
Let me know if you want me to test anything out for a comparison.
It's a shame there isn't a line out on the card. It would probably solve a lot of problems if the amp could be bypassed. Thanks for letting me know about the isolator, I will check out ebay and grab one!
