Gamecollector wrote on 2022-12-16, 19:37:?
Radeon HD3850 AGP + Voodoo2 SLI + WinXPSP3 -- my main retroPC, works flawlessly.
Radeon X1xxx AGP -- not have.
Radeon X850 PE […]
dj_pirtu wrote on 2022-12-15, 13:18:
tried to get any Radeon AGP card to work with Voodoo2 but no, it just won't work. Geforce works.
Radeon X850 PE AGP +... -- graphical artefacts. I will test this Radeon w/o Voodoos. And maybe an oven is the right solution...
Radeon 95xx-98xx AGP -- not have.
And Rageon 8500 SE AGP (9100 to be precise) + Voodoo2 SLI + WinME -- works flawlessly.
The system is P4 3.2E/ASUS P4P800 SE/2 GiB DDR400B RAM/80 GB + 1 TB + 2 TB HDDs (PATA + 2SATA).
How in all that is holy did you get a voodoo 2 to run glide with a ATI Radeon? I own a 9800 pro/ x8x0 and tried many different driver combos with my 2 voodoo 2's.
This is what happens with a ATI 9800 pro on CCC 3.7. Voodoo 2 on fastvoodoo 3.5, installs, however when trying to access display properties I am greeted by a 3DFX DLL error. Once you click ok the panel will open but the voodoo 2 tab is gone, everything else including ATI's tabs are there and functioning. Tried using v2 tweak, it seemed to take the settings, tried running unreal, it saw the voodoo 2 but once you click play it attempts to initialize glide, attempts to open the render window to then hang and pretty much make windows 98se/me go brain dead.
Try fastvoodoo 4.6. display properties works, all tabs present and settings take , but any attempt to run a glide game results in the same issue, attempts to open the render window and hangs.
please share your knowledge of how you got it to work.
