Another CTMOUSE issue
First post, by JayAlien
Hello,
I wonder if someone could point me in the right direction with an issue with CTMOUSE.
I have confirmed working serial mouse, which I’m now trying to get working on my 386.
When I boot the PC, the System configuration splash screen tells me:
Serial Port(s): 3F8
When I run the CTMOUSE.EXE, it responds:
CuteMouse v2.0 alpha 4 [FreeDOS]
Installed at COM1 (03F8h/IRQ4) in Mouse Systems mode
When I look at MSD, mouse reports
Bus Mouse 7.05
When I look at MSD, IRQ settings show
IRQ: 4
Address: D826:0258
Description: COM1: COM3:
Detected: COM1: Bus Mouse
Handled By: CTMOUSE
In MSD, or EDIT or games I have no mouse function. What am I missing?
Thanks,
J
386sx25 SBP2 2M
P75(486) SB16 8M
P133 S3 Vir DX A64g 32M
P233MMX R128Pro A64 64M
Pii400 TNT2 Live! 128M
P3-1G V5 M80 256M
P3-1.4G R8500 A1 256M
A3200 9700 A2 512M
X6800 X850XT A2ZS 1G
E8600 X1950XTX A4pro 2G
QX9650 3870 Xfi 2G
i7-975 GTX570 Xfi 3GB
Reply 1 of 4, by keropi
try an older version like 1.93
in general for me CTMOUSE is more trouble than what is worth and I have reverted to using DRMOUSE from DR-DOS - this is working perfect for me in all my systems and it consumes 6~7kb of ram
Reply 2 of 4, by wbahnassi
I never liked CTMouse's behavior. It has an annoying response curve I couldn't get around with any of the supported params. It's most apparent in Sierra adventure games. Other mouse drivers have a predictable and linear response. I even considered modifying the source for CTMouse to get rid of this annoying acceleration profile, but couldn't do it.
The only valuable feature to me in CTMouse is wheel-button-to-3rd-mouse-button mode. Cool for my Microsoft Wheel mouse, and I use the third mouse button a lot in Sierra games. But I prefer a predictable motion over three-buttons, so I'm using MS MOUSE driver. It loads high, so I don't care about its mem footprint. I have 617KB conv mem which is enough for any thing, and all drivers are in upper memory.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, FDDx3
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 3 of 4, by JayAlien
Keropi, wbahnassi, thanks for your replies. I decided to give msmouse a go, I've tried version 6.26 and 7.04 and in both cases get 'Driver not installed -- interrupt jumper missing'.
It's one of those days where my troubleshooting skills are at zero, I'm going to give this another look tomorrow.
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
A3200 9700 A2 512M
QX9650 3870 Xfi 2G
Reply 4 of 4, by JayAlien
Or I'll keep fiddling with it.
There is a lesson here about basic troubleshooting.
When I run the CTMOUSE.EXE, it NOW responds:
Installed at COM1 (03F8h/IRQ4) in Microsoft mode
and the mouse now works.
I'm using a Microsoft serial mouse that I bought sealed new old stock on ebay. It's from that transitional PS2/serial era, so even though it is a serial mouse, it can be used as a PS2 mouse by detaching the small dongle.
I purchased another serial/PS2 dongle from Amazon, so I could just leave the dongles in the serial ports and switch the mouse between 2 PCs. It doesn't work.
I moved the original MS DB9 to PS/2 to the 386 and now the mouse works. Sigh.
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
A3200 9700 A2 512M
QX9650 3870 Xfi 2G
