First post, by janskjaer
Does dgVoodoo2 support Windows Vista, specifically 64-bit?
I can't find any clear documentation on why Vista wouldn't be supported, but 7 is. What's the difference between the two that would prevent dgVoodoo2 working?
I'm trying to get Direct3D 8 games such as Splinter Cell working on Windows Vista Ultimate 64-bit. However, when I choose the necessary configuration as recommended by pcgamingwiki, the game crashes immediately before starting. The crash error report is empty so I can't diagnose this further, so I don't know where the issue is.
Can anyone give a clear reason why dgVoodoo2 wouldn't work on Vista?
DELL Dimension XPS M200s
:Intel P1 MMX 200MHz
:64MB EDO
:DOS 6.22/Win95b
:Matrox Millenium II + m3D (PowerVR PCX2)
Chaintech 7VJL Apogee
:AMD AthlonXP 2700+
:512MB DDR
:Win98SE/2000 SP4
:3dfx Voodoo5 5500 AGP
Reply 1 of 5, by ZellSF
How do you know it's dgVoodoo, and not the game itself that's not working in Vista?
Reply 2 of 5, by willow
janskjaer wrote on 2022-12-17, 09:58:
Does dgVoodoo2 support Windows Vista, specifically 64-bit? […]
dgvoodoo 2 works with windows vista. I have tried with my laptop.
Reply 3 of 5, by Dege
dgVoodoo should work on Windows Vista because it does not exploit any OS feature that is not available with Vista for D3D11.
I just don't mention Vista in the readme because I myself never tested it on Vista, so, just to make sure.
Reply 4 of 5, by janskjaer
ZellSF wrote on 2022-12-17, 14:29:
Because I was able to run the game (albeit without the D3D8 features enabled) on Vista without dgVoodoo2.
:64MB EDO
:DOS 6.22/Win95b
:AMD AthlonXP 2700+
:512MB DDR
:Win98SE/2000 SP4
Reply 5 of 5, by Rwolf
Maybe entirely unrelated, and I'm not sure which of the SC games included it was now, but back in the day I bought a "splinter cell trilogy" bundle, and one of the games refused to run on my then top-of-the-line XP64 system; I think it was something related to the DRM that differed between the three included games, that was not updated for one of them to work in a 64bit environment.
(My XP64 PC did not have any voodoo hw/sw installed, so it may be unrelated to your issue, since you wrote you had your game working without the dgVoodoo2. I cannot retest on my Vista, since it is 32bit)
