Ess Solo1
First post, by complain77
Hi there, i bougt Ess Solo1 pci audiocard. I cant find any closer info about this revision. it seems it has no sblink, no jumper for amplifier, no ide, no wavetable header. Does someone recognize it? see picture, google is not returning any solid info. thanx for help
Reply 1 of 3, by Kamerat
complain77 wrote on 2022-12-18, 00:29:
This is not the common Terratec TTSOLO card, but an Audiowave AWPCI-SOLO as you might have noticed.
There's some solder pads to the right of the clock crystal that's most likely for SBLINK (PC/PCI).
There's no jumpers for amplifier since the board doesn't contain one, the solder pads are unpopulated.
There's no wavetable header, not even solder pads for it. You can use an external enclosure if you want to use a wavetable board, have a look at Serdashop for options.
YouTube channel
Reply 2 of 3, by complain77
Hi thanx for info! And otherwise it will work as sny other ESS Solo1 card, with same drivers? Dos compatibility with sbpro without SBlink is ok? thank you
Reply 3 of 3, by Kamerat
complain77 wrote on 2022-12-19, 00:30:
Same drivers will work. I'll recommend motherboards with VIA chipsets for best DOS compatibility on the Solo-1. The card will run in DDMA mode on earlier VIA chipsets and TDMA on the later V-Link based ones.
YouTube channel
