Cannot LH Mscdex
First post, by amontre
I'm trying to load high MSCDEX, appreciate any help.
Autoexec.bat
@ECHO OFF
@ECHO OFF
PATH C:\GWN
PATH C:\NC;C:\WINDOWS;C:\WINDOWS\COMMAND
@ECHO OFF
SET BLASTER=A220 I5 D1 H5 P330 E620 T6
@ECHO OFF
SET SOUND=C:\SB16
SET CTCM=C:\CTCM
LH C:\CTCM\CTCM.EXE
LH C:\SB16\AWEUTIL.COM /S
LH C:\SB16\MIXERSET.EXE /P /Q
LH C:\SOFTMPU\SOFTMPU.EXE /mpu:330 /sb:220 /irq:5
@ECHO OFF
GoTo %config%
:EMC
:PRI
:XMC
:CMC
LH C:\WINDOWS\COMMAND\MSCDEX.EXE /D:OPTICAL /E
:EM
:XM
:CM
LH C:\DRIVERS\CTMOUSE.EXE /R2
:E
:X
:C
REM
REM The following lines have been created by Windows. Do not modify them.
REM
C:
CD C:\
CALL C:\WINDOWS\COMMAND.COM
C:\WINDOWS\WIN.COM /WX
Config.sys
DOS=SINGLE
DOS=NOAUTO
[COMMON]
DOS=HIGH,UMB
FILES=30
BUFFERS=30
LASTDRIVE=H
STACKS=9,256
DEVICEHIGH=C:\WINDOWS\IFSHLP.SYS
[menu]
menuitem=EMC, Expanded memory + Mouse + CD-ROM
menuitem=PRI, Expanded memory 16MB + Mouse + CD-ROM
menuitem=PRI2, Extended memory 16MB + Mouse + CD-ROM
menuitem=XMC, Extended memory + Mouse + CD-ROM
menuitem=CMC, Conventional Memory only + Mouse + CD-ROM
menuitem=EM, Expanded memory + Mouse
menuitem=XM, Extended memory + Mouse
menuitem=CM, Conventional memory only + Mouse
menuitem=E, Expanded memory
menuitem=X, Extended memory
menuitem=C, Conventional memory only
menudefault=EMC,11
[EMC]
DEVICE=C:\WINDOWS\HIMEM.SYS /NUMHANDLES=128 /TESTMEM:OFF
DEVICE=C:\WINDOWS\EMM386.EXE X=B800-C7FF I=B000-B7FF RAM M3 A=64 H=128 D=256 AUTO NOTR
DEVICEHIGH=C:\DRIVERS\VIDECDD.SYS /D:OPTICAL
[PRI]
DEVICE=C:\WINDOWS\EMM386.EXE 16384 RAM D=64 I=B000-B7FF
[PRI2]
DEVICE=C:\WINDOWS\EMM386.EXE 16384 RAM D=64 I=B000-B7FF NOEMS
[XMC]
DEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFF
DEVICE=C:\WINDOWS\EMM386.EXE X=B800-C7FF I=B000-B7FF RAM M3 A=64 H=128 D=256 AUTO NOTR NOEMS
[CMC]
[EM]
DEVICE=C:\WINDOWS\EMM386.EXE RAM AUTO HIGHSCAN I=B700-B7FF H=255
[XM]
[CM]
[E]
…Show last 8 lines
[X]
[C]
#1 NEC Pentium 133 | 64mb RAM | 40gb HDD | s3 Virge DX | Voodoo 2 | SB AWE64 Gold
#2 NEC 486DX2 66 | 16mb RAM | 40gb HDD | SB AWE64 Gold
#3 Acer 386 SX 33 | 8mb RAM | 20gb HDD | PicoMEM + Adlib
# Amiga 1200 | MSX2+ | Roland MT-32 | SC 55MkII | YAMAHA MU80
Reply 1 of 11, by dionb
Big config file. Which options do you choose when LH fails?
Reply 2 of 11, by weedeewee
just from looking at the files, I would say that mscdex is only loaded for configuration CMC, which is conventional memory + cdrom + mouse. Not even himem is loaded.
Seems pretty obvious why it's not loading high then.
Do not ask Why !
Reply 3 of 11, by amontre
weedeewee wrote on 2022-12-19, 16:27:
EMC
Reply 4 of 11, by Gmlb256
Actually, MSCDEX gets loaded when XMC, EMC, CMC or PRI are selected. It gets loaded into upper memory if there is enough UMB available (which is the real problem).
amontre wrote on 2022-12-21, 19:03:
EMC
I see that only B000-B7FF is used for UMB which is too small to fit a decent amount of TSRs. Replace that X=B000-C7FF with I=D000-EFFF at least, it should give you plenty of UMB.
Reply 5 of 11, by weedeewee
right, brainfart, forgot that whatever comes first runs through what lies below.
Does the lh mscdex work with PRI2 ?
ps. I personally like to use INSTALLHIGH in config sys
Do not ask Why !
Reply 6 of 11, by Disruptor
Do you need EMS in every config?
If not, replace RAM by NOEMS in your CONFIG.SYS' EMM386 line(s).
Then you have 64k more UMB.
Reply 7 of 11, by amontre
weedeewee wrote on 2022-12-21, 19:15:
Yes it does ! with NOEMS it does load high
Reply 8 of 11, by weedeewee
amontre wrote on 2022-12-21, 20:01:
with the EMC you have
Upper 59,952 34,224 25,728
How many UMB do you have when using the EM configuration ?
if you have more you might want to try adding the HIGHSCAN option to the emm386 commandline in the EMC section
also could you expand more on the expansion cards you have in your computer? SCSI, lan bootrom, ... ?
ps.
another thing to try would be loading these
LH C:\CTCM\CTCM.EXE LH C:\SB16\AWEUTIL.COM /S LH C:\SB16\MIXERSET.EXE /P /Q LH C:\SOFTMPU\SOFTMPU.EXE /mpu:330 /sb:220 /irq:5 […]
LH C:\CTCM\CTCM.EXE
after :C
hopefully ensuring that the largest free umb gets used for loading mscdex, which i'm guessing will be the 32k of the mda space (I=B000-B7FF).
Do not ask Why !
Reply 9 of 11, by Cyberdyne
CTCM and MIXERSET are configuration utilities and not TSR-s. So they do not need to be loaded high.
Reply 10 of 11, by Gmlb256
^ Yep, sometimes these programs get confused as TSRs. AWEUTIL with the /S command line switch will only initialize the EMU8K without getting it loaded as TSR for MPU-401 emulation, making LH unnecessary. It is harmless though.
Reply 11 of 11, by amontre
I solved it by adding "/Q " in himem.sys and additional address "I=C800-EFFF" in emm386.exe . Now mscdex are in upper memory.
