First post, by assortedkingdede
I have been trying to resolve an error where Windows 98SE starts into dos mode, beeps twice and then shows a bunch of gibberish on the screen. When I reinstalled the operating system the same error happened. How can I completely erase the contents of the hard disk so everything is clean slate. (Update: installed in different directory same error).
Reply 1 of 4, by leileilol
Insert a boot disk then formatting the hard drive clean.
though what i'd also try to do is run F-PROT to see if there's a funky prehistoric virus in there, and if not, it could be a RAM/voltage/caps issue, or perhaps the hard drive corrupted a device driver like himem.sys
Reply 2 of 4, by assortedkingdede
leileilol wrote on 2022-12-19, 20:45:
Well I know it is a configuration issue involving a DOS shortcut since it happened after I changed the batch file setting. I tried using FDISK on the startup cd command line but it would not even acknowledge the existence of drive C but I was able to access C drive in the command line.
Reply 3 of 4, by Cosmic
You could try dban if you want to be totally sure there's nothing on the disk. A single zero pass should be sufficient. The last version that runs on standard i386 CPUs and fits on a floppy has filename "dban_1_0_7_i386.ima".
Rigs: Harris 286-16 [WIP] | Am386 DX-40 | i486 DX4-100 | MMX 233 | K6-III+ 600 | P!!!-S 1.3GHz | XP 3200+ 2.3GHz | Q6600 3.2GHz
Reply 4 of 4, by assortedkingdede
Issue resolved, I pulled out another hard disk that had a windows 98 installation and used that to format the broken one.
