First post, by Bruno128
Recreated with some owned authentic components and running Win95 OSR1. Targeted games: 1989 – 1995.
Highlight parts:
  • AMD Am5x86-P75 at 120MHz (because at stock clock “turbo” becomes “suspend”)
  • QDI V4P895GRN/SMT with 256KB UMC UM61256FK-15 cache
  • 32MB TI TMS417400ADJ-60 FPM
  • DTK PTI-265W VLB multi I/O
  • Trident 7352 Rev. G2 TGUI9440AGi VLB 1MB
  • Creative Sound Blaster 16 Pro CT2290
  • Teac FD-55GFR
  • Chinon FZ-357
  • Beige case (as seen in OP)
Misc parts:
  • 3Com EtherLink III 3C509B-C
  • U.S. Robotics internal Sportster 14.4K
  • Serdaco DreamBlaster S2
  • Teac CD-540E
  • Iomega Zip100 ATAPI
  • Apacer AP-FM25644B IDE DOM 256MB
  • LC-Power LC6350 with AT-ATX adaptor (recapped)
58.78 KiB
283.5 KiB
60.52 KiB
How it looked like in 2022
1.41 MiB
Now playing: Red Faction on 2003 Acrylic build
SBEMU compatibility reports
Reply 2 of 8, by Bruno128
Disruptor wrote on 2022-12-23, 16:57:
Perhaps you can upgrade your RAM. But don't use more than 32 MB with your L2 cache configuration.
Thanks for the feedback. If I come across a nice pair of 2x 8MB, I might. I think 16MB would be ample amount here.
But for the record I ran a max allowed amount of 64MB (2x 32MB FPM) in this system and the only trouble associated with it found was incorrectly detected negative value in Norton SI. Neither MEMMAKER nor games were confused by it.
Despite the cacheable amount I also did not notice any performance problems in that scenario.
Reply 3 of 8, by Bruno128
September 2023 update:
RAM is upgraded to a single 32MB FPM module (Texas Instruments TMS417400ADJ-60)
Bus frequency increased to 40MHz, the CPU runs as DX4-120 now. With two VLB cards I am not seeing any instability.
With the new specs Duke Nukem 3D should be playable but I ran into a stuttering problem discussed in 2016 when using DreamBlaster S2 regardless of audio quality, screen size or detail settings.
This post by user orcish75 suggested Duke3D is faster in Windows 95 than in DOS and yes that fixed it. The game runs well in 320x200 with SB16 sound and DreamBlaster MIDI with reported FPS of 20-30.
So the system runs Windows 95 OSR1 now (the one without Internet Explorer, USB, etc.) and I also tested some Windows games:
  • Breakthru! (Spectrum HoloByte, 1994)
  • Lode Runner: The Legend Returns (Sierra, 1994)
  • 3-D Ultra Pinball (Sierra, 1995)
  • Aladdin95 (East Point Software, 1995)
    67.7 KiB
    Aladdin95
All running well.
Trident 9440AGi even has a Windows95 driver that claims some acceleration.
NSSI for the new config
132.76 KiB
NSSI
CACHECHK v7 by Ray Van Tassle: 123.3 MB/s, 51.5 MB/s, 29.8MB/s
83.41 KiB
CACHECHK
Doom fullscreen (from DOSBENCH pack) is 1710 realtics = 43.6FPS.
Reply 4 of 8, by H3nrik V!
Are you sure it's an AMD Am5x86 "DX5-133" I'm pretty sure it would run 133 MHz at 33 MHz FSB and 160 at 40 MHz?
Reply 5 of 8, by Bruno128
H3nrik V! wrote on 2023-09-25, 12:18:
I’m 100% sure, it runs at 3x 40MHz right now. To use 4x multi I would need to upgrade bios (see notes above)
Reply 6 of 8, by H3nrik V!
Bruno128 wrote on 2023-09-25, 12:34:
Ah, I get it ... Apparently I TL;DR'ed that part 🤦 That's a weird quirk, though
Reply 7 of 8, by PC-Engineer
Which BIOS version did you try?
I have this one, which ran fine with Am5x86 as i remember.
    V4P895.zip
    59.51 KiB
    49 downloads
    BIOS QDI V4P895
Epox 7KXA Slot A / Athlon 950MHz / Voodoo 5 5500 / PowerVR / 512 MB / AWE32 / SCSI - Windows 98SE
Reply 8 of 8, by Bruno128
PC-Engineer wrote on 2023-10-07, 05:13:
ran fine with Am5x86.
Hi. Yes, that's the one, ver. 1.4. You are right, 133 does indeed work at normal speed. Did turbo function work for you though? Lack thereof was the deal-breaker for me as I mentioned in the op. If you know how to make turbo work with this bios, please let me know.
