First post, by Bubu2000
Hey guys.
I have a problem with my SBLive CT4620.
I can play games just fine, but everytime I exit the game to the main menu or back to the desktop, the screen turns black, the sound starts looping and the whole system freezes. It doesn't freeze while playing, I can play for hours. It only freezes while switching back to the games main menu or while exiting the game. This happens every time.
Sometimes, but not very often, the system freezes randomly while idling. It even freezes after a fresh win98 install, when no drivers for the card are installed. It's enough that the card is installed in a PCI slot.
Those 2 problems are gone if I remove the card.
What I tried so far:
Different PCI Slots
Automatic and manual IRQ assignment
Different drivers
Recap of the main caps on the card
Specs:
Asus A7V600-X
Athlon XP 1600+
512 MB RAM
60 GB IDE HDD
GeForce FX 5500
Windows 98 SE
Reply 1 of 4, by AlexZ
To rule out driver issues you could try Windows XP. Lastly just try a different card. I have like 4 different types of SB Live. They are very cheap to buy.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 2 of 4, by Gmlb256
The VIA chipset could be the culprit as SBLive! used PCI protocols that VIA didn't bother to implement. On some occasions one could be lucky if that sound card worked fine on these chipsets.
Lastly, the WDM drivers for the SBLive! will be installed by default which aren't reliable in Windows 98. Phil's review of the sound card has a guide for installing the VxD driver around 5:00: https://www.youtube.com/watch?v=z-HiLp5p820&t=300s
Reply 4 of 4, by Bubu2000
Ydee wrote on 2022-12-29, 14:00:
IIRC, some troubles with Creative audio cards like Live! and Audigy on VIA chipsets could be solved with PCI latency patch from G.Breese: https://www.georgebreese.com/net/software/
This patch doesn't work and isn't really needed on newer Chipsets, like my KT600
Gmlb256 wrote on 2022-12-28, 14:29:
I've installed the VXD drivers from that guide, didn't solve the problem.
AlexZ wrote on 2022-12-27, 21:04:
I did that, and it didn't solve my problem. I even bought a new Audigy 2 ZS.
Status update
The problem is solved. It was neither the sound card, nor the chipset or any drivers, but the brand new power supply.
I bought a 460 watt power supply, with 33A on the 3.3V and 5V rail. After some measurements, I found that the power supply can not hold the voltage and fluctuates so much during load changes that the entire PC freezes.
I now bought a Corsair RM 550 X with only 25A on the 3.3V and 5V rails and it works like a charm. The board is rock solid now, not a single crash.
