First post, by Shponglefan
I acquired this memory board configured for 2 MB of RAM. Note, I have added an extra 2MB in the picture below (4MB pictured). I have also confirmed that those extra RAM chips all work by testing all pictured chips in the Bank 0 and Bank 1 rows.
I just need what jumper setting I need to enable to access the additional 2MB of RAM.
Unfortunately, I haven't been able to find any information on this particular board and how to configure it. It uses a Boca Research chip, but all the Boca Research boards I've looked up all have different layouts and more jumpers and switches than this particular board.
This board only has two jumpers (J1 & J2) and no switches.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 1 of 7, by Disruptor
Something must be wrong because it already has 4 MB populated.
Reply 2 of 7, by Shponglefan
Disruptor wrote on 2022-12-26, 23:15:
Yes, I populated that extra RAM (I have also confirmed that it all works by trying all chips in the bank 0 and bank 1 rows). Unfortunately I am not able to get it working past 2MB and I don't know what jumper settings I might need to configure to make it work with that.
That's why I want to see if there is any documentation on the required jumper settings.
Reply 3 of 7, by Ozzuneoj
EDIT: Whoops! The link I posted had exactly what you're looking for and I didn't notice it at first. This post:
Re: ISA XMS/EMS Memory Extension / Expansion cards: Now Running without Driver / Documentation :-)
You need to configure it with software, which is available in that post. The jumpers are there to allow for multiple cards in the same system
I found the same board in this thread and you can just barely see where the jumpers are... and it looks to be the same as yours, so I'm thinking maybe the jumpers aren't the problem.
https://forum.vcfed.org/index.php?threads/lot … 1-monitor.4519/
Also found some posts of similar (but not Boca) cards here, and at least one was configured via software.
Maybe yours needs some kind of program to change the settings? Couldn't hurt to at least try programs for other similar cards, just in case they are compatible.
I have found lots of results for "8 meg at ram" , but nothing as clear as a list of jumper settings.
Reply 5 of 7, by Shponglefan
Ozzuneoj wrote on 2022-12-26, 23:59:
This did the trick, thank you!
I hadn't thought that it might be a software configuration issue (outside of BIOS setup). But running that install program from that post did detect and configure the full 4MB.
Reply 6 of 7, by Ozzuneoj
Shponglefan wrote on 2022-12-27, 00:47:
Awesome! Glad I could help. 😀
Reply 7 of 7, by Horun
maxtherabbit wrote on 2022-12-27, 00:04:
Nice ! specifically: http://filedump.glitchwrks.com/mirrors/ftp.bo … d/File_area_20/ Memory Boards.
I grabbed them all and will add to Vogons library later... thanks
