First post, by biessea
Hi there folks,
I have just repaired a nice baby AT Motherboard, to finally take out the strength from my AMD K6/3+ processor. I will finally let to use the 100mhz FSB and the 6x hidden multiplier.
So I assembled all the system and all works, but when I install the VIA chipset drivers, I encounter a problem. The system become so slow.
It came out that the UDMA mode is slowing all here, like the VIA chipset simply can't handle it.
I tried Via Hyperion 4.35, 4.41, 4.56.
I am using a Windows 98SE operative system to enjoy gaming with a nice Geforce 2 GTS 32MB.
How can I use UDMA driver so? If not, can I load at least the Multiword DMA?
Someone can help me about that? Thanks a lot.
I have a 40GB hard disk Seagate Barracuda 7200.7 ST340014A
Computer lover since 1992.
Love retro-computing, retro-gaming, high-end systems and all about computer-tech.
Love beer, too.
Reply 1 of 20, by keropi
what version of the 4in1 drivers are you installing?
the latest is not always the best when in comes to the via 4in1 driver - for my 591Ps I always install v4.35 and I never faced an issue
Reply 2 of 20, by paradigital
keropi wrote on 2022-12-28, 09:50:
My guess is that he’s tried these versions of the 4-in-1, just a hunch mind you.
biessea wrote on 2022-12-28, 09:11:
What other devices or peripherals do you have connected/installed? Any USB?
Reply 4 of 20, by biessea
that is the FIRST one version that I have tried.
If I enable UDMA system slow down, like really irresponsive.
Love beer, too.
Reply 5 of 20, by biessea
paradigital wrote on 2022-12-28, 09:56:
My guess is that he’s tried these versions of the 4-in-1, just a hunch mind you. […]
I have the internal USB header connected and working, a LAN card, an AWE64 ISA card, and a AGP (2x mode enables by bios) VGA Geforce 2 GTS.
Love beer, too.
Reply 6 of 20, by biessea
I just reinstalled the VIA driver, version 4.43 and when I installing them and check the box "enable DMA mode" after restart the system is completely slow, like four-five times longer during the Windows 98SE loading. There could be some conflict or problems with the VIA MVP3 chipset and this mode?
I see that the hard disk led is continously working and after one second of work it blink, this happens continuosly. always a blink in the same amount of time. Probably the driver can't use that DMA mode and slow down all the system.
Love beer, too.
Reply 7 of 20, by Roman555
Hi there folks,
Hi,
Try to not install VIA IDE driver at all. IIRC during the installation process customize and disable VIA IDE driver in the checkbox. You will be able to set UDMA in the Windows device manager (Disk Drives -> Disk Drive type 47 or something -> Settings - DMA checkbox) later.
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 8 of 20, by Gmlb256
Roman555 wrote on 2022-12-28, 13:23:
Hi there folks,
Hi,
Try to not install VIA IDE driver at all. IIRC during the installation process customize and disable VIA IDE driver in the checkbox. You will be able to set UDMA in the Windows device manager later.
Windows 98 didn't come with IDE drivers for VIA chipsets out of the box. 😖
Reply 9 of 20, by biessea
I tried older VIA drives and the issue is permanent.
I read other users that normally install VIA driver in a MVP3 chipset board and work.
What the hell has my motheboard? How can I solve that issue?
Now I try to remove VIA drivers that I installed for now, there is a software to correctly remove them?
It is better at this point that I use Windows 2000?
Love beer, too.
Reply 10 of 20, by Roman555
Gmlb256 wrote on 2022-12-28, 13:36:
But what about "Standard IDE driver" ? IMO it's enough for this case
P.S. A good Phil's explanation how to change dma mode in bios settings
How to enable DMA mode in Windows 95 or 98
    8.15 KiB
Reply 11 of 20, by biessea
I am installing Windows 2000 now in another hard disk, Wester Digital Caviar 40GB.
So I will try this different operative system and changing hard disk can exclude the problem that the other Seagate "could" have.
I will let you know immediately.
Love beer, too.
Reply 12 of 20, by Gmlb256
Roman555 wrote on 2022-12-28, 14:47:
But what about "Standard IDE driver" ? IMO it's enough for this case […]
Doesn't work with every motherboard chipset and PIO mode will be forced on unsupported ones in Windows.
Reply 13 of 20, by biessea
Anyway happy to say that I have installed Windows 2000 SP4 Professional in another hard disk, a WD Caviar 40GB, and all works flawlessly, after installing the Via Hyperion Driver 4in1 4.35.
No more slow down, hard disk running correctly.
It seems the problem was Win98SE with this kind of motherboard, or chipset, or perhaps the hard disk?
Love beer, too.
Reply 14 of 20, by keropi
biessea wrote on 2022-12-28, 16:09:
could be the hard disk, I am using the 591P+98SE+4.35 combo for a couple decades now
my 591P is also 3.1
Reply 15 of 20, by Roman555
Gmlb256 wrote on 2022-12-28, 15:22:
But it worth to try. My Win95 on DFI MVP3 system (VT82C596 + 80-wire IDE cable + Samsung UDMA ATA66):
    217.19 KiB
Reply 16 of 20, by Gmlb256
Roman555 wrote on 2022-12-28, 17:36:
Ok, at least the VIA MVP3 chipset works with the generic IDE drivers supplied by Microsoft. So, it is indeed worth a try.
My apologies for doubting you.
Reply 17 of 20, by Roman555
Gmlb256 wrote on 2022-12-28, 17:44:
The problem is I don't remember how I installed the drivers as it was years ago. So I'm not sure and maybe you are right. I will recheck
P.S. I've dig into VIA driver-install-software and found out there're two drivers: viavsd.inf and viaide.inf.
I can misinterpret my digging but it seems viavsd.inf relies on a microsoft standard driver mshdc.inf but viaide.inf relies on a VIA MPD driver.
So, Gmlb256, I apologize too. The VIA IDE driver seemed to be installed but it looks like in my system the microsoft standard driver works.
I was confused because VIA installed driver usually shows in Windows Device Manager "VIA Bus Master PCI IDE Controller" (not "Standard Dual PCI IDE Controller").
I don't know what utility can show which driver is working now. I've installed SiSoft Sandra 99 but it can't.
P.P.S. The via driver installer also copied vatapi.vxd , but I didn't find any links to it in registry or ini-files so I guess it just loads during Windows start from system\iosubsys automatically and also works
Reply 18 of 20, by Roman555
biessea, if I were you I would try to understand what type of VIA driver has been installed: MPD (miniport driver) or VSD driver and then try to exchange. It seems in my system is installed VSD (although Windows 95 says nothing about it and even pretends it a standard one 😀 ) and DMA works
P.S. interesting topic about VIA DMA
VIA Chipset Issues with SSD and DMA
Reply 19 of 20, by biessea
keropi wrote on 2022-12-28, 16:46:
my 591P is also 3.1
I am just thinking about this.
Could be the hard disk.
So I installed Windows2000 in a Western Digital that now I have partitioned with a fat32 partition where I installed Windows98se.
Now I will install the Via driver 4.35 and I will let you know, just I solve the problem of the LAN PCI card that doesn't work correctly to run this system on net sharing files with my primary computer.
Love beer, too.
