First post, by Chadti99
I’ve got an AHA-1542cf that’s delaying system startup on every boot at “Waiting for SCSI id #0”. After a solid minute or two it eventually moves on and boots the system. It wasn’t doing this until I reset the adapter settings to default in the ctrl+a menu. How do I resolve this? The only device I have connected is an NEC optical drive detected at id #3.
I know I could disable the bios but was wanting to test booting from CD-ROM.
Reply 1 of 12, by TheMobRules
Not sure about the AHA-1542CF as I don't have one, but on other Adaptec controllers you can enter the config utility (Ctrl+A) and select which IDs you want to include in the BIOS scan. By default all the IDs are set to "yes" so they will be scanned at boot, you can set all of them to "no" except for #3 (your CD-ROM drive) and #7 (usually this is the adapter itself).
Reply 2 of 12, by Chadti99
Makes sense! I can’t for the life of me find a way to select what’s included in the scan. I’ll do some research.
Reply 3 of 12, by auron
how about putting the optical drive at #0? should be just no jumper on the id# pins.
Reply 4 of 12, by Sphere478
Indeed, set it to zero
Scanning di0……….. nothing
Scanning id1………… nothing
Scanning id2……….. nothing
Scanning id3………… cd!
Scanning id4……. Nothing
Gives up, boots? Idk…
Vs
scanning id0….. cd
Rest disabled, booting!
Sphere's PCB projects.
Reply 5 of 12, by Chadti99
Thanks, changing the SCSI ID to 0 did the trick.
You guys will get a kick out of this, I don’t think this mobo supports booting from CD, even if it’s SCSI.
https://youtu.be/NoeM84TddzE
Reply 8 of 12, by TheMobRules
This post claims that it is possible to boot from CD-ROM if you update the BIOS to v2.11. Normally you can't access the optical drive in DOS without loading the ASPI CD driver, but looks like this BIOS versions does allow booting?
Reply 9 of 12, by rasz_pl
its booting from CD just fine right into boot menu, but there is already garbage on Windows 98 boot screen.
Reply 10 of 12, by Chadti99
rasz_pl wrote on 2022-12-29, 18:44:
Yep I think you are right, although I’ve not been able to guess the correct menu options to get it to fully boot the CD. I wonder what’s causing the screen corruption and beeping?
This is on a Biostar 8433uud.
Reply 11 of 12, by Chadti99
I got it, just had to press the #2 at the right time and made it to this screen. Very cool.
Reply 12 of 12, by Chadti99
So update on this, there must of been a resource conflict to cause the trashed video output on CD boot. Tried it again today and it works perfect on the Biostar 8433UUd.
