First post, by miller11568
I have no Nvidia/AMD video card, but when I decided to play Army Ranger: Mogadishu, I got an error saying:
Failed to intialize the renderer. Please ensure your video card meets the minimum requirements, your video drivers are up to date, and you are running the required version of Microsoft DirectX ®.
Same error occured using dgVoodoo.
Are there ways to address this error to be able to play Army Ranger: Mogadishu without a video card?
Reply 1 of 7, by BEEN_Nath_58
As you said you own no Nvidia or AMD card, it could be useful to tell a litte about your specifications first
Reply 2 of 7, by miller11568
What is "Failed to intialize the renderer. Please ensure your video card meets the minimum requirements, your video drivers are up to date, and you are running the required version of Microsoft DirectX." and how do I get rid of this?
Reply 3 of 7, by myne
It literally says what the problems might be and what to check.
Do that.
When you've done that, learn how to list what you've got(hardware, software) , and things you have tried to fix it.
I built:
Reply 4 of 7, by soggi
The answer by the Publisher of the Game (Groove Games) to this question is the following:
https://web.archive.org/web/20100126030654/http://www.groovegames.com/retail-army-ranger-mogadishu.html wrote:
Hardware T&L Not Supported ('Failed to Initialize the Renderer' error)
'Failed to Initialize Renderer' means that your video card does not fully support the features required by Army Ranger. Specifically, your card does not support Hardware Transform and Lighting functions, often referred to as Hardware T&L.; Essentially, it's a portion of the math and setup for the graphics that the video card handles instead of the main CPU.
You will have to buy a new video card to get Army Ranger to work properly on your computer. We can recommend any video card using either the Nvidia Geforce FX or ATI Radeon 9000 processors (or better) for Army Ranger. The starter cards from either series can be found for well under $100. Upgrading your video card will usually result in noticeably better graphics and a significant increase in performance.
Hopefully, this is enough to help you.
kind regards
soggi
Vintage BIOSes, firmware, drivers, tools, manuals and (3dfx) game patches -> soggi's BIOS & Firmware Page
soggi.org on Twitter - inactive at the moment
Reply 5 of 7, by miller11568
What file offset from the exe or DLL do I find and hex edit to bypass this error "Failed to initialize the renderer" and be able to play Army Ranger: Mogadishu without a video card instead of buying one?
Reply 7 of 7, by soggi
miller11568 wrote on 2025-01-14, 15:44:
... and be able to play Army Ranger: Mogadishu without a video card instead of buying one?
You have no video card / GPU!? How do you get an image, how did you read the error message, how do you want to play the game? This makes no sense to me.
As said above, you need a GPU with T&L to play the game. The renderer seems to need it...if you however find a way to SW emulate T&L then it could be incredibly slow, I guess, depends on the CPU.
kind regards
soggi
