First post, by tomcattech
Thinking about my next retro rig to cover the XP to Win 7 Era.
Need some help with hardware from CPU\motherboard choice, video\sound solution down to power supply rating.
For anyone that knows me I'm shooting for "overpowered" but also "stable\compatible".
I know chipsets and drivers for both Win 7 and XP are going to be a thing.
For older game compatibility I'm going to keep it 32 bit.
Any ideas for hardware and from those that are running this type of rig would be of massive help.
Thanks!
Reply 1 of 4, by Shponglefan
These are the current specs of my 'ultimate' Windows XP rig. I specifically tried to build the fastest possible 32-bit XP machine, but still maintaining as much compatibility as possible.
As I understand it, it's possible to go higher spec (e.g. 4790k) under Windows XP, but at that point compatibility becomes more of an issue.
I haven't yet dual-booted this system w/ Windows 7, but I imagine it would have no issues (I used to dual boot an E8400 rig with XP/7 ).
MB: Asus P8Z68-V Pro/Gen 3 motherboard
CPU: i7-3770k CPU
RAM: 2x2GB DDR3 RAM (Corsair XMS3)
GPU: eVGA GeForce GTX 980Ti
Audio: Creative Labs X-Fi Titanium Fatal1ty Champion
Storage: 250GB + 500GB Samsung EVO 840 SSD (dual drives)
Removeable Storage: LG DVD Rewriter
Power Supply: Seasonic 750W Prime 80 Plus Gold
Case: Fractal Design Focus G
Cooling: Be Quiet Shadowrock 2 Cooler, 2x Corsair ML120 120mm fans (CPU cooler/rear), 2x Fractal Design 120mm fans (front)
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 2 of 4, by tomcattech
After much deliberation I've decided to go the small form factor route on a dedicated XP machine using the HP Elite 8200 SFF.
I'm currently working on some hardware upgrades for it and should wind up sort of like Phil's system here:
https://youtube.com/watch?v=C5QjZJvook8&feature=shares
If I get it locked down I may try dual boot Win XP\Win 7.
I'll keep this thread updated as I push along.
Reply 3 of 4, by dj_pirtu
My triple-booting (DOS/Windows98SE, WinXP, Win10) ultimate all-arounder has:
Asus A8V Deluxe (last VIA chipset which supports PCI-DMA so SB PRO support in DOS with ESS SOLO-1 PCI sound card)
Athlon 64 X2 4200+
2GB RAM
Radeon 3850 AGP
Voodoo 3 PCI
Audigy2
ESS SOLO-1
Reply 4 of 4, by tomcattech
Well, here it is.... my new XP rig all set up.
Upgraded with an SSD, 4 GB RAM and a Radeon HD 7750.
Plays Far Cry on max settings smooth as silk.
Overall it is based on a rig I saw over on Phil's Computer Lab.
(Darn you Phil.... Stop giving me ideas to spend money on....)
    17.68 KiB
