First post, by Mister98XPee
I was going to run Windows ME on a VHD I found and to do that I need VPC2007 for best compatiblity outside of PCEM so I would like to know why whenever it is I installed it I got so close yet so far on virtualbox? I can install it but as soon as I click on the exe to actually run it I get a crash and yes this is 32 bit version for 32 BIT OS guest. It was hell to even get to the install pointsince even with Virtualbox installation of guest images I couldn't drag and drop and couldn't use shared folders,etc which is a shame they dropped support of it.
I downloaded the 2004 which seems to work where as the 2007 crashes. Never mind that it dosn't work either. I can't get to the part where I can config my virtual hard disk it skips that unlike the tutorial video here. https://www.youtube.com/watch?v=vUswiY9nuYw which shows the guy manually config so therefore I get boot error because of no hard disk.
Reply 1 of 6, by Jo22
Virtual PC 2004/2007 worked fine for me for years.
I ran it on both Windows XP SP2/SP3. Guests were ranging from DOS+WfW, OS/2 Warp to Vista. Edit: Win Me included.
Since it's Freeware now, I can send you my backup copy of Virtual PC, if it can help you.
This shouldn't be against the rules, I guess.
I've downloaded it from the official Microsoft servers, including the patches and the 64-Bit version of Virtual PC 2007.
Edit: A stumbling stone might be hardware-assisted virtualization.
It fixes Win32s on Windows 3.1x, but makes Windows 9x unstable (in VPC).
It also crashes certain PCs upon activation.
The expiration date issue might be related to the guest.
Maybe that VM was a beta version of Me, in order to not break rules of distribution.
Reply 2 of 6, by DosFreak
The last Vmware Player I tested on XP was "VMware-player-6.0.7-2844087.exe". You are much better off with vmware. I say that as someone who used VPC from the beginning.
Vmware workstation is v7.1.6 for a 32bit cpu, 10.0.7 needs a 64bit cpu.
You may run into an edge case where the emulated S3 video card in VPC works for something that the vmware one does not but it's extremely rare.
Note that 9x guests are superior on pcem for graphics since it has 3D acceleration. The minimum for vmware for 3d acceleration is Windows 2000.
Make your games work offline
Reply 3 of 6, by Mister98XPee
Jo22 wrote on 2023-01-12, 18:59:
Virtual PC 2004/2007 worked fine for me for years. I ran it on both Windows XP SP2/SP3. Guests were ranging from DOS+WfW, OS/2 W […]
I finally found a VPC that worked which was VPC 2004 but the sound makes farting noises when turning it on and any sound plays on a Win9X install either fresh or a downloaded VM.
Reply 4 of 6, by Jo22
Mister98XPee wrote on 2023-01-23, 05:54:
Glad to hear! 😁 Err, not the farting noise, of course. If you like, I send you a PM to a backup of my Virtual PC collection (VPC 2004/2007, patches, drivers, documents etc).
Free and legal stuff only, of course. All the commercial releases aren't useful, anyway, since they are from the 90s and incompatible with Windows.
Reply 5 of 6, by Mister98XPee
Jo22 wrote on 2023-01-23, 06:04:
Thanks! When you send it I'll try that on the laptop next chance I get to to see how that goes and also try the VMware route to see which is better for running Land Before Time Activity Center and/or Sim Copter. Virtual Machines just crash on the laptop where they work a lot better on the desktop. Weird. I think Dell has some kind of weird way of pointing things to addresses on their older laptops that the desktops don't have.
Reply 6 of 6, by Errius
I've been using VPC2007 right up until a few weeks ago when I finally switched to Windows 10 from 8.1. It's unfortunate that it won't run on Windows 10 as I now no longer have access to my DOS/Windows 9x/NT VMs. (I tried running VPC inside of Hyper-V but it just crashes the W81 guest OS.)
So I should switch to VMWare?
"AI Requires Proof That You Are Human"
