BIOS programming
First post, by mrgreen
Hello,
I need to program a SST 29EE010 BIOS chip, which should be compatible with AWARD BIOS CHIP called PCI/PNP 586, for a socket 7 asus motherboard.
Which programmer tool (like ti886) should I use? What kind of procedure should I follow?
Thanks for your suggestions.
My first PC had Windows 98 os.
Reply 1 of 1, by megatron-uk
I've just used my TL866 to flash a SST29EE010 bios this week. I use the Linux software, minipro, but the Windows application should work fine
Make sure that if you buy a TL866 that it comes with the PLCC32 adapter (most bundles include at least that along with several more).
Other than that, it's a modern electrically writeable device so it should just work.
https://www.target-earth.net
