First post, by Nexxen
I am on the process of replacing some aluminium electrolytic caps, but I can't find a match.
They leaked with a brownish residue on the bottom and they are less than half their value.
Mobo won't boot anymore, it went from fan spinning to instant power off.
On the top:
8 5
680 (this is µF)
4J
I don't get if they are 4V or 8.5V 680µF.
Thanks!
Edit: it's 85 mm (height) , 680 is µF value, 4j is indeed 4V.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 1 of 11, by Jo22
https://www.electronics-notes.com/articles/el … es-markings.php
It doesn't have 4J in the list, though. 🙁
If you can't figure out the meaning for markings, you can try measure the voltage, as a last resort.
As a rule of thumb, I would use a value that's a little bit higher.
Because, voltage spikes regularly happens with all digital components (on/off toggling creates power surges and spikes,
even if we're in a micro second or nano second scale).
So if there's 5v applied, a 6.3v cap is near its limit already. I'd use a higher voltage model.
Same with 12v and a 16v cap. I'd use a 25v cap here.
Of course, that's just me. Most people would argue that's not necessary.
And that ESR is so much more important, et cetera pp..
Reply 2 of 11, by Nexxen
pics
Reply 4 of 11, by Nexxen
Excuse my ignorance, I can safely solder some 1000µF 6.3V to test if the board isn't dead?
Reply 5 of 11, by Nexxen
weedeewee wrote on 2023-01-15, 08:57:
I'm guessing it's 680µF 4V 5% tolerance.
Likely on the 3v3 rail.
One is shorting between +5VUSB and -12V (I think it's because of a NPN or PNP not closing some MOSFET / gate / xxx when V is applied - I found this situation before, until I check "live" I'm assuming it's okay).
The other one I can't retrace it for the same reason I presume, until a gate is opened.
I guess +12V, +5V have some good circuitry (caps + mosfets), maybe +3V just has a cap and one mosfet.
At first the mobo would power on, then after some retries and in the end 1 every 20 times and then just inst shutdown.
Probably the caps (from my basic experience). I just don't wanna mess it up as I like this little board 😀
Reply 6 of 11, by weedeewee
Nexxen wrote on 2023-01-15, 14:35:
yes. if it fits you could even put a 400V in there., just don't go too far overboard with the capacitance. best to stick with, as close to, the original value present.
Do not ask Why !
Reply 7 of 11, by weedeewee
Nexxen wrote on 2023-01-15, 15:59:
The 'one is shorting between +5VUSB and -12V' seems off to me. That would be a voltage difference of 17V, and I also do not see any reason to put a capacitor between those two.
Let's hope it's just some measurement oddness.
I would expect all the grounds of the capacitors be continuous to ground, and the positive to a voltage rail. could be 3v3, could be some lower voltage used for ram or cpu. likely DDR2 1.8V .
Do not ask Why !
Reply 8 of 11, by Nexxen
I found a voltage regulator with a shorted mosfet, shorts with all leads (G/D/S).
I may have put the wrong +12V in the 4-pin header. It's the only thing I can think of.
Reply 9 of 11, by Nexxen
weedeewee wrote on 2023-01-15, 16:46:
The 'one is shorting between +5VUSB and -12V' seems off to me. That would be a voltage difference of 17V, and I also do not see […]
Most definitely something died somewhere, board is shutting down immediately.
I'm desoldering the dead mosfet and see what happens.
What a wonderful sunday afternoon 😀
Reply 10 of 11, by Nexxen
Ok, it was a dead mosfet on the VRM.
Once removed it works well.
The caps I removed were all above 20% loss and half the rated value, I guess it was just good to replace them.
Unless anyone wants to say anything this is solved.
Thanks for playing. 😀
Reply 11 of 11, by Nexxen
🤣 second time I fired it up I got some magic smoke from another mosfet, I have only one vrm line left...
The first that died put some strain on the other two and I guess the last one is waiting to die as well.
Nice 😀
--- THE END ---
