First post, by kashmoney
I bought one of these Matrox F7003-0301 Rev.A G450 cards from aliexpress.
https://www.aliexpress.com/item/1005003147103 … .2cf318023tpdz3
I installed the card and the Matrox driver setup won't recognize the video card for some reason... I'm installing it in a Compaq Deskpro EN which has an integrated GPU that I've disabled. I'm using Windows 98 SE.
I previously had a Trident 9440-1 installed in the PCI slot that worked well.
I tried both versions of the driver from phils computer lab that support the G450 (682 and 683).
https://www.philscomputerlab.com/drivers-for-matrox.html
Any ideas on what to try?
Edit: I've also tried manually updating from the generic driver windows installed by pointing to the matrox driver folder and it doesn't change the driver.
Reply 1 of 3, by Sphere478
I ended up force installing the driver. Worked fine after that. Manually select in driver update
Sphere's PCB projects.
Reply 2 of 3, by kashmoney
Sphere478 wrote on 2023-01-16, 22:04:
Awesome, thanks...
It's been a long time since I've done this sort of thing, so thought that's what I was doing, but you're right, it worked perfectly when I went to "Display list of all the drivers in a specific location" navigated to the folder with the driver and selected the G450 DualHead PCI from the list.
Reply 3 of 3, by Sphere478
Yep 😀
Idk why auto detection isn’t working. Prob the card has a unrecognized HW ID
Might be able to flash it to a recognized card?
