First post, by BoYan
Hello all,
This is maybe my 1st post in Vogons, and I write about a problem 😁
I'm also one of the guys trying to get period correct collections of AGP cards (all the way up to Radeon HD 3850), and somewhere along the way, I had most problem to find Radeon 8500/9000/9100, as they were not very much used in the county in which I'm living (Serbia).
I managed to find one Radeon 8500 card which I can hear posting, but output is only completely white screen, without any anomalies or corruptions, just simply put - white screen 100%.
I tried both VGA output, DVI to VGA (passive) and DVI to VGA (active), and all 3 show the same - white screen.
Let me mention I checked card for physical damage, and in this relatively short period, I could not find any missing components, only some minor (I would say not important) scratches. Card seems as it was working for quite a while (ball bearing on the fan was sounding like a lawnmower, before I added some machine oil).
Test platform is nforce3 250 GB/ultra board (DFI LanParty nf3), if it can lead to this anomaly, due to some incompatibility?
Did you ever see such a problem, I tried googling it and no relevant results come out... 😒
EDIT: not my 1st post, I was wrong 😁
Reply 1 of 10, by Roman555
Might it be that the graphic card is for Apple Mac ? It's better to attach photos of the card and maybe someone will spot something.
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 3 of 10, by Roman555
BoYan wrote on 2023-01-18, 08:36:
actually most of the stickers on the card were scratched out, i there another way to recognize a MAC edition card?
AGP connector seems to me is standard and the PC does POST with card in the slot.
Have you tried to connect a monitor to another PC or video card ? Maybe instead of the graphics card the monitor is broken...
Reply 6 of 10, by Roman555
BoYan wrote on 2023-01-18, 14:35:
actually it's my test setup, and my daily monitor, I already tested 40-50 cards on same monitor 😉
Have I understood right that the white screen appears just after power-on (even during BIOS post-screen or in DOS)? I mean is it not a problem of ATI windows drivers?
I remember there was a problem with the latest legacy ATI driver in windows 7 (or maybe also in XP).
Also I would try to add into the system a PCI video card as a primary graphics adapter and look up the radeon among PCI devices in windows manager or in AIDA or similar utilities.
Reply 7 of 10, by BoYan
So as asked, I attach the hi-res photos of the Radeon...
EDIT: yes, the white screen appears on BIOS post, so from 1st screen, I didn't try booting into windows as on this PC I don't have a system installed.
Reply 8 of 10, by Roman555
BoYan wrote on 2023-01-19, 08:11:
There're some missing components - mostly electrolytic capacitors and also ceramic ones.
I got this picture as a reference , P/N is the same : 109-85700-00
Maybe you'll spot more. Good luck!
It's difficult to say without a schematic diagram or measurement which are really important and cause faulty behavior of the card.
Also maybe the card became a donor of capacitors years ago when someone understood or supposed the GPU was faulty. But for me the pads look like the smd capacitors were just scraped, although pads of dip capacitors look soldered .
Reply 9 of 10, by pentiumspeed
This guy needs resistance values for these resistors at given locations, (they are black film) with white ceramic under it.) Ditto to cream coloured SMD ceramic capacitor values.
Help the guy please.
Cheers,
Great Northern aka Canada.
Reply 10 of 10, by acl
I'm no expert but I tried my best.
So for identification, i assumed that black smd components are resistors, tan ones are capacitors.
I compared to my own 8500 "standard" (Not LE, Not DV, Not AIW). Can be seen here : https://retro.user-unfriendly.net/Parts/Graph … 20AGP/pictures/
Mine is a bit different because it has a tv out.
I added numbers to the identified missing components.
371.19 KiB
Back of the card :
1:
Top to bottom :
Not connected
Resistor 240 marking
Capacitor unknown value
Resistor 000 marking
Resistor 240 markings 4 inputs
2:
3, 5, 6:
From top to bottom :
4 :
Top to bottom :
Not connected
7 :
Resistor. No markings. ~1.2K Mesured
8 :
Big capacitor on the other side of the board
9:
10:
11:
12:
13 :
Resistor. No markings. ~1.7K Mesured
14:
15:
383.47 KiB
Front of the card :
16:
Capacitor Code 470 jFK 1QN = 470uF 63v
17:
Capacitor Code L1 47j UD = 47uF 6.3v
18:
Capacitor Code HC L2 470 10V = 470uF 10v
19:
20:
21:
22:
8500 are rare in France too. It took me a few years to find one.
I hope I will help.
